跳转到主内容
Sony SLT Alpha-65V Motherboard Replacement
你所需要的
  1. Sony SLT Alpha-65V Motherboard Replacement, LCD Screen: 步骤 1 中的图像 1,2 Sony SLT Alpha-65V Motherboard Replacement, LCD Screen: 步骤 1 中的图像 2,2
    • Remove the two 4.0 mm Phillips #00 screws on the base of the camera.
    • Remove the 3.0 mm Phillips #00 screw on the hinge of the screen.
  2. Sony SLT Alpha-65V Motherboard Replacement: 步骤 2 中的图像 1,2 Sony SLT Alpha-65V Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the two 2.0 mm Phillips #00 screws on the bottom-right side of the screen.
    • Remove the two 2.0 mm Phillips #00 screws on the bottom-left side of the screen.
  3. Sony SLT Alpha-65V Motherboard Replacement: 步骤 3 中的图像 1,1
    • Use the plastic opening tool to gently pry the screen open around the entire screen.
  4. Sony SLT Alpha-65V Motherboard Replacement: 步骤 4 中的图像 1,3 Sony SLT Alpha-65V Motherboard Replacement: 步骤 4 中的图像 2,3 Sony SLT Alpha-65V Motherboard Replacement: 步骤 4 中的图像 3,3
    • The brown ribbon and white light on the edge of the screen are extremely loose and will fall off off. Keep the screen flat at all times to make sure they don't come out.
    • Use a plastic opening tool to disconnect the silver wires from the screen's circuitry and completely remove the screen from the camera.
  5. Sony SLT Alpha-65V Motherboard Replacement, Back Panel: 步骤 5 中的图像 1,1
    • Unscrew the four 4.0 mm Phillips #00 screws with a on the base of the camera below the the scheme that separates the front and back panels.
    • Unscrew the 5.0 mm Phillips #00 screw on the bottom right of the camera.
  6. Sony SLT Alpha-65V Motherboard Replacement: 步骤 6 中的图像 1,1
    • Unscrew the 4.0 mm Phillips #00 screw on bottom of the left side of the camera.
    • Unscrew the 5.0 mm Phillips #00 screw near the top of the left side of the camera.
  7. Sony SLT Alpha-65V Motherboard Replacement: 步骤 7 中的图像 1,1
    • Be careful when pulling the back panel away as it will still be connected to the body of the camera by two strips of film.
    • When unscrewing the 5.0 mm screw on the dial, make sure to hold onto the dial that becomes detached after taking out the screw.
    • Unscrew the two 4.0 mm Phillips #00 screw at the top of the camera by the eyepiece.
    • Unscrew the 5.0 mm Phillips #00 screw of the dial below the other two screws.
    • Once all the screws are removed, carefully use your hands to detach the back panel from the camera. Working around the edges can help as well.
  8. Sony SLT Alpha-65V Motherboard Replacement: 步骤 8 中的图像 1,3 Sony SLT Alpha-65V Motherboard Replacement: 步骤 8 中的图像 2,3 Sony SLT Alpha-65V Motherboard Replacement: 步骤 8 中的图像 3,3
    • Remove the two 4.0 mm Phillips #00 screws on the right of the camera that are located on the upper right side and under the "Remote" port flap.
    • Detach the right side panel with the remote and HDMI ports of the camera by gently pulling on the panel.
  9. Sony SLT Alpha-65V Motherboard Replacement: 步骤 9 中的图像 1,1
    • When the back panel is removed, be careful when moving the camera. There are parts inside the camera which now may come loose.
    • Use tweezers to remove the blue and orange ribbon connectors from their connection points pictured here.
  10. Sony SLT Alpha-65V Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,1
    • Remove the four 3.0 mm Phillips #00 screws.
    • Remove the 5.0 mm Phillips #00 screw.
  11. Sony SLT Alpha-65V Motherboard Replacement: 步骤 11 中的图像 1,3 Sony SLT Alpha-65V Motherboard Replacement: 步骤 11 中的图像 2,3 Sony SLT Alpha-65V Motherboard Replacement: 步骤 11 中的图像 3,3
    • Don't forget to close these switches and lock the film back into place when reassembling the camera.
    • Use your finger to flip the switch that holds the dual ribbon connector in place.
    • Gently use tweezers to disconnect the dual ribbon connector and the thin blue ribbon connector to the right of it from the circuit board.
  12. Sony SLT Alpha-65V Motherboard Replacement: 步骤 12 中的图像 1,3 Sony SLT Alpha-65V Motherboard Replacement: 步骤 12 中的图像 2,3 Sony SLT Alpha-65V Motherboard Replacement: 步骤 12 中的图像 3,3
    • Use tweezers to disconnect the blue, gold, and brown ribbon connectors near the top of the camera.
  13. Sony SLT Alpha-65V Motherboard Replacement: 步骤 13 中的图像 1,2 Sony SLT Alpha-65V Motherboard Replacement: 步骤 13 中的图像 2,2
    • Use a plastic opening tool to pop open the connector holding the next ribbon to the circuit board.
    • Use tweezers to disconnect the ribbon.
  14. Sony SLT Alpha-65V Motherboard Replacement: 步骤 14 中的图像 1,1
    • Use tweezers to unplug the blue adapter located at the top right of the circuit board.
  15. Sony SLT Alpha-65V Motherboard Replacement: 步骤 15 中的图像 1,1
    • Use either plastic opening tools or tweezers to unplug the white adapter located on the right side of the circuit board.
  16. Sony SLT Alpha-65V Motherboard Replacement: 步骤 16 中的图像 1,1
    • The circuit board will still be connected to the body of the camera by two pairs of cords.
    • Gently lift the circuit board away from the camera and turn it over.
    • Use tweezers to disconnect the final two plugs and completely remove the circuit board from the camera.
结论
12等其他人完成本指南。
Alexander Lisso
于04/22/15注册
597 声望
创作了2篇指南
团队
Cal Poly, Team 14-11, Amido Spring 2015 Cal Poly, Team 14-11, Amido Spring 2015 的会员
CPSU-AMIDO-S15S14G11
4 名成员
创作了13篇指南
4条评论
I posted this link to a "Can't read SD card problem" below. On most SLTmodels apparently the SD card reader is part of the main circuit, and my local repair shop wanted $160 for labor (!) to swap out the part:
My camera is not recognizing any memory cards
Tomas loomis - 回复
does anyone know if replacing the motherboard would fix a fried aperture lever control motor?
Scott Steeves - 回复
My camera will not read SD cards and intermittent struggles with lens connections. I sent it out for repair and the response was as follows: “AM main board would need to be replaced and is no longer available.” Is the AM main board another name for the Mother Board?
Jim Bowie - 回复
Does any know can i buy the flex cable for view finder button?
sarojnbo - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 6
过去 30 天: 28
总计 2,769
