跳转到主内容
Sony Reader Touch Edition PRS-600 Power Button Replacement
你所需要的
  1. Sony Reader Touch Edition PRS-600 Power Button Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
  2. Sony Reader Touch Edition PRS-600 Power Button Replacement: 步骤 2 中的图像 1,1
    • Slide the back cover off by pushing it to the left, away from the side that held the screws.
    • Remove the cover.
  3. Sony Reader Touch Edition PRS-600 Power Button Replacement: 步骤 3 中的图像 1,1
    • This is what the device should look like once the back cover panel has been removed.
  4. Sony Reader Touch Edition PRS-600 Power Button Replacement, Battery: 步骤 4 中的图像 1,1
    • Once the back cover has been removed locate the battery in the bottom right corner of the device.
    • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
  5. Sony Reader Touch Edition PRS-600 Power Button Replacement: 步骤 5 中的图像 1,1
    • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
  6. Sony Reader Touch Edition PRS-600 Power Button Replacement, Power Button: 步骤 6 中的图像 1,1
    • Remove the stylus from the device.
  7. Sony Reader Touch Edition PRS-600 Power Button Replacement: 步骤 7 中的图像 1,3 Sony Reader Touch Edition PRS-600 Power Button Replacement: 步骤 7 中的图像 2,3 Sony Reader Touch Edition PRS-600 Power Button Replacement: 步骤 7 中的图像 3,3
    • Using the Phillips screwdriver remove the 1.4 mm screw from the top panel.
    • Using the same screwdriver, remove the 1.4 mm screw from the back of the device.
    • Pry apart off the top panel of the device.
结论
Zachary Jeffers
于10/13/14注册
412 声望
创作了4篇指南
团队
Clemson, Team 1-4, Benson Fall 2014 Clemson, Team 1-4, Benson Fall 2014 的会员
CLEM-BENSON-F14S1G4
4 名成员
创作了22篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 738
