跳转到主内容
Sony Reader Touch Edition PRS-600 Battery Replacement
你所需要的
  1. Sony Reader Touch Edition PRS-600 Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
  2. Sony Reader Touch Edition PRS-600 Battery Replacement: 步骤 2 中的图像 1,1
    • Slide the back cover off by pushing it to the left, away from the side that held the screws.
    • Remove the cover.
  3. Sony Reader Touch Edition PRS-600 Battery Replacement: 步骤 3 中的图像 1,1
    • This is what the device should look like once the back cover panel has been removed.
  4. Sony Reader Touch Edition PRS-600 Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • Once the back cover has been removed locate the battery in the bottom right corner of the device.
    • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
  5. Sony Reader Touch Edition PRS-600 Battery Replacement: 步骤 5 中的图像 1,1
    • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
结论
8等其他人完成本指南。
Terrika Ngobili
于10/13/14注册
857 声望
创作了7篇指南
团队
Clemson, Team 1-4, Benson Fall 2014 Clemson, Team 1-4, Benson Fall 2014 的会员
CLEM-BENSON-F14S1G4
4 名成员
创作了22篇指南
2条评论
It works great - thanks very much for this guide!
kitimatwoz - 回复
where can i buy the battery for replacement ?? what battery is ? Answer me pls on: edgarjacob16@gmail.com
Edgar Jacob - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 58
总计 4,666
