跳转到主内容
Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement
你所需要的
  1. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement, Sony Radio Model CFD S05 Prerequisite steps Replacement: 步骤 1 中的图像 1,1
    • Unscrew the screws on the top of the radio.
  2. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: 步骤 2 中的图像 1,2 Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: 步骤 2 中的图像 2,2
    • Open the CD and cassette doors and remove the screws in the compartments.
    • To open the CD door push on the bottom left corner of the CD door. To open the cassette door push the button that is to the left of the pause button.
  3. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: 步骤 3 中的图像 1,1
    • Flip the radio upside down and remove the battery cover. Unscrew the one screw below the batteries.
  4. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: 步骤 4 中的图像 1,1
    • Remove the top of the radio enough to access the wires for removal.
    • Do not forcefully remove the whole top piece of the radio! There will be wires connected to the top cover and circuit board.
  5. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: 步骤 5 中的图像 1,1
    • Remove all of the wires that are connected to both the circuit board and the underside of the top of the radio by pulling them where they are connected
    • This should include three sets of red and white wires, one set of white wires, one set of black wires, and two ribbon wires. Some cannot be disconnected from the top piece of the radio. Disconnect these plugs from the circuit board.
  6. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement, Belt for the Tape Motor: 步骤 6 中的图像 1,1
    • Locate the motor of the radio on the underside of the top of the radio.
  7. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: 步骤 7 中的图像 1,1
    • Unscrew the screw holding the motor to the top of the radio.
  8. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: 步骤 8 中的图像 1,1
    • Lift up the motor.
    • Don't lift too high because the motor stand will break.
  9. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: 步骤 9 中的图像 1,1
    • Unhook the larger band from under the motor and remove it.
  10. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: 步骤 10 中的图像 1,1
    • Replace the band by hooking it beneath the motor.
  11. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: 步骤 11 中的图像 1,1
    • Push the motor back down and screw it into place.
结论
3等其他人完成本指南。
Ian Nussman
于10/25/13注册
959 声望
创作了6篇指南
团队
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2013 UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2013 的会员
UMASSD-GULBRANDSEN-F13S2G5
2 名成员
创作了6篇指南
一条评论
I'm worried about removing wires. How do you put them back? Doesn't that take some kind of special equipment/glue?
Carolyn Farley - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 47
总计 5,091
