跳转到主内容
Sony RMT-D197A Battery Contactor Repair
你所需要的
  1. Sony RMT-D197A Battery Contactor Repair, Sony RMT-D197A Battery Contactor Repair: 步骤 1 中的图像 1,2 Sony RMT-D197A Battery Contactor Repair, Sony RMT-D197A Battery Contactor Repair: 步骤 1 中的图像 2,2
    • Place the remote on a solid, sturdy surface.
    • Use a putty knife to gently pry open the remote.
  2. Sony RMT-D197A Battery Contactor Repair: 步骤 2 中的图像 1,2 Sony RMT-D197A Battery Contactor Repair: 步骤 2 中的图像 2,2
    • Remove the front panel from the remote.
  3. Sony RMT-D197A Battery Contactor Repair: 步骤 3 中的图像 1,1
    • Wear safety glasses and use caution when handling a hot soldering iron.
    • Use the soldering iron to gently desolder the damaged battery contactor.
    • Keep in mind the battery contactor can easily break so make sure to be gentle with the soldering iron.
  4. Sony RMT-D197A Battery Contactor Repair: 步骤 4 中的图像 1,2 Sony RMT-D197A Battery Contactor Repair: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to remove the spring from the contactor.
  5. Sony RMT-D197A Battery Contactor Repair: 步骤 5 中的图像 1,1
    • Use the soldering iron to melt solder onto the empty hole.
    • Make sure to accurately place the spring into the correct position.
  6. Sony RMT-D197A Battery Contactor Repair: 步骤 6 中的图像 1,2 Sony RMT-D197A Battery Contactor Repair: 步骤 6 中的图像 2,2
    • Reattach the two halves of the remote.
  7. Sony RMT-D197A Battery Contactor Repair: 步骤 7 中的图像 1,1
    • Insert batteries and try out your remote.
终点
3等其他人完成本指南。
Ahmed Sultan
于09/10/21注册
193 声望
撰写一个指南
团队
York University, Team 2-10, O'Regan Fall 2021 York University, Team 2-10, O'Regan Fall 2021 的会员
YORK-O'REGAN-F21S2G10
1 名成员
创作了2篇指南
一条评论
As the remote is already disassembled, I took the opportunity to clean the contacts for all the buttons using alcohol.
Jason Lee - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 443
