跳转到主内容
Sony RM-LVR1 Motherboard Replacement
你所需要的
  1. Sony RM-LVR1 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the four (4) screws on the back of the device.
    • If the screws strips or is previously stripped, refer to the stripped screw repair guide.
  2. Sony RM-LVR1 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Battery is the rectangular and silver object in the center of device.
    • Remove battery with finger by prying at the rear.
    • If unable to remove battery, pry out using spudger.
  3. Sony RM-LVR1 Motherboard Replacement, LCD Screen: 步骤 3 中的图像 1,2 Sony RM-LVR1 Motherboard Replacement, LCD Screen: 步骤 3 中的图像 2,2
    • Unscrew the 3 (three) screws holding the bracket in place.
    • Then remove the bracket by prying one end up.
    • Do not rip the ribbon cable connecting the bracket to the motherboard.
  4. Sony RM-LVR1 Motherboard Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • With tweezers, unplug the ribbon cable from the white connector.
  5. Sony RM-LVR1 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove motherboard from the device by pulling upward gently, with fingers or tweezers.
  6. Sony RM-LVR1 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Gently push out on these two clips holding the LCD to the motherboard
    • Once you have the first two off, ever so carefully, push the LCD towards the remaining two clips.
    • There is a ribbon cable underneath the LCD connecting it to the motherboard. Avoid sharp, sudden movements to prevent it from being damged
  7. Sony RM-LVR1 Motherboard Replacement: 步骤 7 中的图像 1,2 Sony RM-LVR1 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Undo the ribbon cable attached between the motherboard and screen by prying up black tab which holds the cable, using spudger. (See pictures)
  8. Sony RM-LVR1 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the screen from the motherboard.
结论
另外一个人完成了本指南。
一条评论
Hello
Thank you for your tutorial.
My question is about the rubber cap of the push button
Can it be changed? Spare part ?
Regards
gilbert keiser - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 291
