跳转到主内容
Sony RM-LVR1 LCD Screen Replacement
你所需要的
  1. Sony RM-LVR1 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the four (4) screws on the back of the device.
    • If the screws strips or is previously stripped, refer to the stripped screw repair guide.
  2. Sony RM-LVR1 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Battery is the rectangular and silver object in the center of device.
    • Remove battery with finger by prying at the rear.
    • If unable to remove battery, pry out using spudger.
  3. Sony RM-LVR1 LCD Screen Replacement, LCD Screen: 步骤 3 中的图像 1,2 Sony RM-LVR1 LCD Screen Replacement, LCD Screen: 步骤 3 中的图像 2,2
    • Unscrew the 3 (three) screws holding the bracket in place.
    • Then remove the bracket by prying one end up.
    • Do not rip the ribbon cable connecting the bracket to the motherboard.
  4. Sony RM-LVR1 LCD Screen Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • With tweezers, unplug the ribbon cable from the white connector.
  5. Sony RM-LVR1 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Remove motherboard from the device by pulling upward gently, with fingers or tweezers.
  6. Sony RM-LVR1 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Gently push out on these two clips holding the LCD to the motherboard
    • Once you have the first two off, ever so carefully, push the LCD towards the remaining two clips.
    • There is a ribbon cable underneath the LCD connecting it to the motherboard. Avoid sharp, sudden movements to prevent it from being damged
  7. Sony RM-LVR1 LCD Screen Replacement: 步骤 7 中的图像 1,2 Sony RM-LVR1 LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Undo the ribbon cable attached between the motherboard and screen by prying up black tab which holds the cable, using spudger. (See pictures)
  8. Sony RM-LVR1 LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Remove the screen from the motherboard.
结论
另外一个人完成了本指南。
4指南评论
здорово!
подскажите где купить дисплей?, или его маркировку?. на дисплее ничего не написано, не могу найти.
Александр - 回复
Hi
I cant find an replacement lcd.
Could anybody help me where to get one?
Cheers
Sven
Sven van Bellen - 回复
any link to the replacement LCD please?
Bart Ptachowski - 回复
Hi .
search : HD 170 LCD Drift aliexp****
i think it will do the job .
cheers
ruigyl - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 25
总计 733
