跳转到主内容
Sony RDR HX750 HX950 Disassembly
你所需要的
  1. Sony RDR HX750 HX950 Disassembly, Remove cover: 步骤 1 中的图像 1,3 Sony RDR HX750 HX950 Disassembly, Remove cover: 步骤 1 中的图像 2,3 Sony RDR HX750 HX950 Disassembly, Remove cover: 步骤 1 中的图像 3,3
    • Remove the screws from the back and sides of the top cover.
  2. Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: 步骤 2 中的图像 1,3 Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: 步骤 2 中的图像 2,3 Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: 步骤 2 中的图像 3,3
    • Remove the four screws that secure the hard drive mounting bracket to the bottom of the unit.
    • Unplug the two cables from the rear of the hard drive.
    • Remove the four screws from the bottom of the hard drive mounting bracket.
  3. Sony RDR HX750 HX950 Disassembly, Remove DVD player: 步骤 3 中的图像 1,3 Sony RDR HX750 HX950 Disassembly, Remove DVD player: 步骤 3 中的图像 2,3 Sony RDR HX750 HX950 Disassembly, Remove DVD player: 步骤 3 中的图像 3,3
    • Remove the screws from the DVD cover
    • Remove the screws from the plastic cable holder
  4. Sony RDR HX750 HX950 Disassembly, Remove front Panel: 步骤 4 中的图像 1,3 Sony RDR HX750 HX950 Disassembly, Remove front Panel: 步骤 4 中的图像 2,3 Sony RDR HX750 HX950 Disassembly, Remove front Panel: 步骤 4 中的图像 3,3
    • Insert the paper under each "click" to remove the front panel.
    • Once each "click" is loose, push the front panel gently.
    • The table of the compact disk has a little plastic piece in front that goes up to come out with a "click"
  5. Sony RDR HX750 HX950 Disassembly, Remove  DVD block: 步骤 5 中的图像 1,3 Sony RDR HX750 HX950 Disassembly, Remove  DVD block: 步骤 5 中的图像 2,3 Sony RDR HX750 HX950 Disassembly, Remove  DVD block: 步骤 5 中的图像 3,3
    • Unplug the cables show in photo.
    • Disconnect the cable hidden on the side.
    • Remove the piece on the cd reader
  6. Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: 步骤 6 中的图像 1,3 Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: 步骤 6 中的图像 2,3 Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: 步骤 6 中的图像 3,3
    • Under the DVD block, remove the screws as shown.
    • Remove the screws on the board.
    • Now the laser can be accessed.
  7. Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: 步骤 7 中的图像 1,3 Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: 步骤 7 中的图像 2,3 Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: 步骤 7 中的图像 3,3
    • Inserir instruções aqui.
结论
To open this dvd recorder folow this tutorial
2等其他人完成本指南。
Cafony
于02/17/15注册
687 声望
创作了4篇指南
一条评论
Hello,HX950 work only with hdd 250Gb,or another,with 500 or 1000Gb ???
Cornelus - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 49
总计 5,377
