跳转到主内容
Sony Pulse Elite Edition Headband Replacement
你所需要的
  1. Sony Pulse Elite Edition Headband Replacement, Remove Headband Screws: 步骤 1 中的图像 1,2 Sony Pulse Elite Edition Headband Replacement, Remove Headband Screws: 步骤 1 中的图像 2,2
    • Remove the two 5mm Phillips #00 screws from each side of the headband connected to the metal track.
  2. Sony Pulse Elite Edition Headband Replacement, Remove Plastic Screw Bracket: 步骤 2 中的图像 1,2 Sony Pulse Elite Edition Headband Replacement, Remove Plastic Screw Bracket: 步骤 2 中的图像 2,2
    • After removing the screws, push the small plastic protector on one of the sides towards the speaker closest to it.
    • After the protector has slid out of its slot, pull it away from the bar until it pops off the track.
    • Repeat this process for small plastic protector on the other side.
  3. Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: 步骤 3 中的图像 1,3 Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: 步骤 3 中的图像 2,3 Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: 步骤 3 中的图像 3,3
    • Using your thumb, slide the cushion on one of the two adjusting rails toward the closest speaker.
    • Once enough of the cushion has separated from the rail, pull the rest of it off.
    • Repeat the process for the other rail.
  4. Sony Pulse Elite Edition Headband Replacement, Slide Headband Off Rails: 步骤 4 中的图像 1,1
    • Gently pull the headband away from one of the speaker component groups, as if expanding it. Continue pulling until it is completely off the track.
    • Remove the white and red wires from inside the headband.
    • Be sure to keep the two speakers close together since they are still linked via the speaker wires.
    • Repeat this process for the other side.
结论
3等其他人完成本指南。
Chris Echter
于01/29/15注册
865 声望
创作了4篇指南
团队
Clemson, Team 14-2, Shirley Spring 2015 Clemson, Team 14-2, Shirley Spring 2015 的会员
CLEM-SHIRLEY-S15S14G2
5 名成员
创作了12篇指南
一条评论
have any experience with the sony gold headset, i got two of them that broke in the same spot, right at the hinge
Rich Gallagher - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 28
过去 30 天: 89
总计 5,834
