跳转到主内容
Sony PlayStation 3D Display Power Port Replacement
你所需要的
  1. Sony PlayStation 3D Display Power Port Replacement, Rear Case: 步骤 1 中的图像 1,2 Sony PlayStation 3D Display Power Port Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Remove the base by pushing in the button and sliding out the unit.
  2. Sony PlayStation 3D Display Power Port Replacement: 步骤 2 中的图像 1,3 Sony PlayStation 3D Display Power Port Replacement: 步骤 2 中的图像 2,3 Sony PlayStation 3D Display Power Port Replacement: 步骤 2 中的图像 3,3
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. Sony PlayStation 3D Display Power Port Replacement: 步骤 3 中的图像 1,2 Sony PlayStation 3D Display Power Port Replacement: 步骤 3 中的图像 2,2
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Sony PlayStation 3D Display Power Port Replacement: 步骤 4 中的图像 1,3 Sony PlayStation 3D Display Power Port Replacement: 步骤 4 中的图像 2,3 Sony PlayStation 3D Display Power Port Replacement: 步骤 4 中的图像 3,3
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
  5. Sony PlayStation 3D Display Power Port Replacement, Power Port: 步骤 5 中的图像 1,3 Sony PlayStation 3D Display Power Port Replacement, Power Port: 步骤 5 中的图像 2,3 Sony PlayStation 3D Display Power Port Replacement, Power Port: 步骤 5 中的图像 3,3
    • With the Phillips #02 screwdriver, remove the two 5mm length x 7mm head screws from the left and right side of the power port plate.
  6. Sony PlayStation 3D Display Power Port Replacement: 步骤 6 中的图像 1,3 Sony PlayStation 3D Display Power Port Replacement: 步骤 6 中的图像 2,3 Sony PlayStation 3D Display Power Port Replacement: 步骤 6 中的图像 3,3
    • Remove the power port by depressing the white tab attached to the wires.
结论
另外一个人完成了本指南。
Logan Simon
于10/08/15注册
234 声望
撰写一个指南
团队
Cal Poly, Team 12-16, Maness Fall 2015 Cal Poly, Team 12-16, Maness Fall 2015 的会员
CPSU-MANESS-F15S12G16
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 1,566
