跳转到主内容
你所需要的
视频概述
这个拆解是不是维修指南。 要维修你的的PlayStation 2,请使用我们的维修手册
  1. Sony PlayStation 2 Teardown, Sony PlayStation 2 Teardown: 步骤 1 中的图像 1,3 Sony PlayStation 2 Teardown, Sony PlayStation 2 Teardown: 步骤 1 中的图像 2,3 Sony PlayStation 2 Teardown, Sony PlayStation 2 Teardown: 步骤 1 中的图像 3,3
    • On the front right side of the console we have the On/Off and the Eject button for the DVD player.
    • On the front left side we can see the two USB ports and the Firewire port. Two memory card slots, and the two controllers inputs.
  2. Sony PlayStation 2 Teardown: 步骤 2 中的图像 1,3 Sony PlayStation 2 Teardown: 步骤 2 中的图像 2,3 Sony PlayStation 2 Teardown: 步骤 2 中的图像 3,3
    • Let's start with the teardown!
    • First of all we need to remove the Network Adaptor, which also gives you the choice to install a HDD.
    • The third picture shows where the hard disk would be placed.
  3. Sony PlayStation 2 Teardown: 步骤 3 中的图像 1,3 Sony PlayStation 2 Teardown: 步骤 3 中的图像 2,3 Sony PlayStation 2 Teardown: 步骤 3 中的图像 3,3
    • This is the network adaptor we just removed, let's take a look at it before we move on to the console..
  4. Sony PlayStation 2 Teardown: 步骤 4 中的图像 1,3 Sony PlayStation 2 Teardown: 步骤 4 中的图像 2,3 Sony PlayStation 2 Teardown: 步骤 4 中的图像 3,3
    • Turn the console upside down and with a flathead screw remove the rubber covers that hide the 8 screws.
    • On the back right of the console we can clearly see the warranty seal... the point of no return!
    • Once the seal and the screws are gone lift the upper part of the console and get ready to uncover the secrets of the PS2.
  5. Sony PlayStation 2 Teardown: 步骤 5 中的图像 1,3 Sony PlayStation 2 Teardown: 步骤 5 中的图像 2,3 Sony PlayStation 2 Teardown: 步骤 5 中的图像 3,3
    • First of all let's remove the power supply by removing the four screws. In the blue box you can see the large fan, which is in front of the power supply to make sure the temperature is kept as low as possible, and to protect the "Emotion Engine".
    • Here's a closer look at the massive power supply.
  6. Sony PlayStation 2 Teardown: 步骤 6 中的图像 1,3 Sony PlayStation 2 Teardown: 步骤 6 中的图像 2,3 Sony PlayStation 2 Teardown: 步骤 6 中的图像 3,3
    • Here is what is left when the power supply is gone.
    • Now we can easily remove the protective case for the optional hdd.
    • Done that we can unlock the optical drive from the metal frame.
  7. Sony PlayStation 2 Teardown: 步骤 7 中的图像 1,3 Sony PlayStation 2 Teardown: 步骤 7 中的图像 2,3 Sony PlayStation 2 Teardown: 步骤 7 中的图像 3,3
    • Next we need to remove the plastic layer that protects the power supply so we can access to the screws beneath it.
    • Once all the screws are gone we can lift the metal frame by using a flathead screw and some leverage to unlock all four sides from the plastic case of the optical drive.
  8. Sony PlayStation 2 Teardown: 步骤 8 中的图像 1,3 Sony PlayStation 2 Teardown: 步骤 8 中的图像 2,3 Sony PlayStation 2 Teardown: 步骤 8 中的图像 3,3
    • Before revealing the heart of our PS2 we need to remove the massive heat sink that prevents the "Emotion Engine" from overheating.
    • A closer view of the beautiful heat sink.
    • One last thing before removing the metal frame is unplugging the fan from the circuit board.
  9. Sony PlayStation 2 Teardown: 步骤 9 中的图像 1,3 Sony PlayStation 2 Teardown: 步骤 9 中的图像 2,3 Sony PlayStation 2 Teardown: 步骤 9 中的图像 3,3
    • Here is the bottom part of the circuit board.
    • Some pictures of the board.
  10. Sony PlayStation 2 Teardown: 步骤 10 中的图像 1,3 Sony PlayStation 2 Teardown: 步骤 10 中的图像 2,3 Sony PlayStation 2 Teardown: 步骤 10 中的图像 3,3
    • More pictures
  11. Sony PlayStation 2 Teardown: 步骤 11 中的图像 1,3 Sony PlayStation 2 Teardown: 步骤 11 中的图像 2,3 Sony PlayStation 2 Teardown: 步骤 11 中的图像 3,3
    • Before flipping the board and see where all the fun takes place we need to unplug a few connectors that transport data form the circuit board to the optical drive.
  12. Sony PlayStation 2 Teardown: 步骤 12 中的图像 1,3 Sony PlayStation 2 Teardown: 步骤 12 中的图像 2,3 Sony PlayStation 2 Teardown: 步骤 12 中的图像 3,3
    • And here it is... the EE "Emotion Engine" Some specifics about the EE: CPU 128 Bit running at 300 MHz
    • RDRAM 32 MB
    • The GS "Graphics Synthesizer" with its clock frequency of 150 MHz, DRAM Bus Bandwidth 48 GB per second, DRAM Bus width 2560 bits and a Maximum Polygon Rate of 75 million polygons per second... pretty impressive
  13. Sony PlayStation 2 Teardown: 步骤 13 中的图像 1,3 Sony PlayStation 2 Teardown: 步骤 13 中的图像 2,3 Sony PlayStation 2 Teardown: 步骤 13 中的图像 3,3
    • A look at one of the two RDRAM of the PS2..
    • ..at the USB and Firewire ports..
    • ...and more pictures.
  14. Sony PlayStation 2 Teardown: 步骤 14 中的图像 1,3 Sony PlayStation 2 Teardown: 步骤 14 中的图像 2,3 Sony PlayStation 2 Teardown: 步骤 14 中的图像 3,3
    • One last thing to take a look at is the optical drive...
  15. Sony PlayStation 2 Teardown: 步骤 15 中的图像 1,2 Sony PlayStation 2 Teardown: 步骤 15 中的图像 2,2
    • On the side of the DVD player there's a little battery that helps the PS2 to keep up with date and time even when not plugged in... not bad..
    • There's a look at the bottom side of the optical drive.
  16. Sony PlayStation 2 Teardown: 步骤 16 中的图像 1,3 Sony PlayStation 2 Teardown: 步骤 16 中的图像 2,3 Sony PlayStation 2 Teardown: 步骤 16 中的图像 3,3
    • Unfortunately our teardown is over, it was really fun, hope you enjoyed it too.
matte18
于10/12/09注册
405 声望
创作了2篇指南
2条评论
I found there were some details lacking in this teardown, and as soon as I removed the top half of the case, I realised my PS2 was quite different inside. I did my own teardown with pix. Want it?
kitadran - 回复
Yes please; can you upload the pictures please
Justin - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 95
过去 30 天: 477
总计 71,501
