跳转到主内容
Sony PS-LX300USB Motor Replacement
你所需要的
  1. Sony PS-LX300USB Motor Replacement, Dust Cover: 步骤 1 中的图像 1,1
    • Turn the turntable around so that the back side is visible.
  2. Sony PS-LX300USB Motor Replacement: 步骤 2 中的图像 1,2 Sony PS-LX300USB Motor Replacement: 步骤 2 中的图像 2,2
    • Begin by releasing the left latch. Apply downward pressure to the square, black button using a flathead screw driver.
    • Once the latch is released, lift upward.
    • Use your left hand to hold the left side of the dust cover above the latch. This ensures the latch does not reconnect.
  3. Sony PS-LX300USB Motor Replacement: 步骤 3 中的图像 1,1
    • Use a flat head screw driver to apply pressure to the black square button on the right side.
  4. Sony PS-LX300USB Motor Replacement: 步骤 4 中的图像 1,2 Sony PS-LX300USB Motor Replacement: 步骤 4 中的图像 2,2
    • Once both the right and left buttons are released, pull the dust cover upwards.
    • The dust cover is now disconnected and ready for replacement.
  5. Sony PS-LX300USB Motor Replacement, Drive Belt: 步骤 5 中的图像 1,2 Sony PS-LX300USB Motor Replacement, Drive Belt: 步骤 5 中的图像 2,2
    • Lift the rubber mat, and put it to the side. It should be easy to remove, because it simply rests on a metal platter without anything securing it down.
  6. Sony PS-LX300USB Motor Replacement: 步骤 6 中的图像 1,1
    • Turn the platter so that the motor pulley can be seen through one of the two outer holes in the platter.
    • If the drive belt is hooked around the motor pulley, unhook it.
    • When reassembling to device, don't forget to hook the new drive belt to the motor pulley.
  7. Sony PS-LX300USB Motor Replacement: 步骤 7 中的图像 1,1
    • Grasping the platter by its two inner holes, lift it upwards.
    • Removing the platter may take a small amount of force. If the pulley is unhooked and the tone arm is safely to the side, don’t fear using a small amount of force in lifting the platter.
    • If you haven’t yet unhooked the drive belt, the motor pulley and the belt could sustain damage.
  8. Sony PS-LX300USB Motor Replacement: 步骤 8 中的图像 1,2 Sony PS-LX300USB Motor Replacement: 步骤 8 中的图像 2,2
    • Peel the drive belt from the inner ridge of the metal platter and put it to the side.
    • Sometimes, the drive belt can fall off the platter during deconstruction. If this is the case, simply take it out of the device wherever it is.
  9. Sony PS-LX300USB Motor Replacement, Motor: 步骤 9 中的图像 1,2 Sony PS-LX300USB Motor Replacement, Motor: 步骤 9 中的图像 2,2
    • Use a PH2 screwdriver to remove the 8 screws from the bottom cover.
    • Now lift the bottom cover to remove it.
  10. Sony PS-LX300USB Motor Replacement: 步骤 10 中的图像 1,1
    • The motor is in the right upper corner area of the turntable, shown in the red square.
  11. Sony PS-LX300USB Motor Replacement: 步骤 11 中的图像 1,1
    • Using a solder iron, carefully desolder the wires that are connected to the old motor to be able to remove it. Making sure to pay close attention where each wire is connected.
    • From left to right: Black is all the way to the left. Red is next. White is third. Yellow is all the way to the right.
    • When reassembling, do not forget to solder in the wires in their previous places.
  12. Sony PS-LX300USB Motor Replacement: 步骤 12 中的图像 1,1
    • Remove the old motor by turning it counterclockwise, freeing it from its position.
    • When reassembling, place the new motor in by aligning the two screws and turning the motor clockwise to secure it.
结论
Christian Fuentes
于09/27/17注册
116 声望
撰写一个指南
团队
Cal Poly, Team S8-G3, Banghart Fall 2017 Cal Poly, Team S8-G3, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S8G3
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 36
总计 3,361
