跳转到主内容
Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device
视频概述
  1. Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device, Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 1 中的图像 1,3 Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device, Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 1 中的图像 2,3 Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device, Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 1 中的图像 3,3
  2. Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 2 中的图像 1,2 Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 2 中的图像 2,2
    • Install Sony PC Companion in your PC.
  3. Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 3 中的图像 1,3 Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 3 中的图像 2,3 Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 3 中的图像 3,3
    • From here you can update your firmware, but when you connect the phone, it must be switched on and not in security or password screen.
    • We will start "Support Zone" because from here we can flash the phone from switched off state regardless of whether there is a password.
    • Now start "Phone / Tablet Software Update".
  4. Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 4 中的图像 1,3 Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 4 中的图像 2,3 Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 4 中的图像 3,3
    • Connect your laptop to power supply since the update of your phone will take some time.
    • Now choose "repair my phone / tablet". By this way you can fully erase your phone and remove any security password, PIN etc., or change firmware if your phone have OS problem and can't be powered on correctly.
    • This is your last warning about losing your personal data.
  5. Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 5 中的图像 1,2 Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 5 中的图像 2,2
    • PC Companion will download some files to prepare your PC for software update.
    • Your phone / tablet must be at last 80% for the update to proceed safely!
  6. Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 6 中的图像 1,2 Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 6 中的图像 2,2
    • Select the model of your phone.
    • You should not confuse the model.
  7. Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 7 中的图像 1,3 Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 7 中的图像 2,3 Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 7 中的图像 3,3
    • The USB cable must be connected only to the PC.
    • Turn off the phone.
    • Press and hold the Volume Down button while plugging the cable into your phone.
    • Once connected, PC Companion will download necessary firmware and will upload it to your phone.
  8. Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 8 中的图像 1,3 Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 8 中的图像 2,3 Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 8 中的图像 3,3
    • Your PC must recognize your phone like SOMC Flash Device.
    • If you have a problem with drivers (your PC can't recognize your phone), search in the internet for "S1Boot Fastboot" drivers or use the link below.
    • Direc link to Android WinUSB drivers
  9. Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 9 中的图像 1,3 Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 9 中的图像 2,3 Sony PC Companion - How to Flash Password Locked or Not Powered Xperia Device: 步骤 9 中的图像 3,3
    • When PC Companion finished with update process, disconnect the phone and switch it on.
    • Now your phone is in factory condition, with erased custom data and without password protection.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
结论
36等其他人完成本指南。
ZFix
于12/09/13注册
191,278 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,532篇指南
6条评论
how much time to take to dowmload. evenafter 2 hours it completed only nearly 9percent
prabha karan - 回复
Facing issue while flashing frimware try this, i have try to keep is easy and simple..
Here is link for that:https://www.youtube.com/watch?v=q7zDA94g...
hemang vyas - 回复
HI, I HAVE UPLOADED 10 GB DATA TO LAPTOP WITH XPERIA COMPANION TOOL WHILE TAKING BAKE-UP OF PHONE (Sony e5563, Sony Xperia C5 Ultra Dual), NOW I WANT TO GET THOSE DATA BACK, BUT ITS ASKING FOR PASSWORD & I DON'T REMEMBER IT. WHAT TO DO PLEASE GUIDE ME.
Lokanathan - 回复
cannot even enter pc companion because it says "your device is locked"
Al Ced - 回复
Yes I did this successfully - thank you!
For those who, like me, had the "black screen of death" issue and Xperia Companion is telling you your device is locked, close down Companion, unconnect your phone from your laptop/tablet and start again using the instructions above. If you do this right it lets you bypass the locked screen. You have to do everything in the order above otherwise it won't work
Nicola Haughian - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 74
总计 83,931
