跳转到主内容
Sony NWZ-E473 Battery Replacement
你所需要的
  1. Sony NWZ-E473 Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
  2. Sony NWZ-E473 Battery Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to loosen the bottom portion of device.
  3. Sony NWZ-E473 Battery Replacement: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to loosen the top panel of the device.
  4. Sony NWZ-E473 Battery Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
  5. Sony NWZ-E473 Battery Replacement: 步骤 5 中的图像 1,3 Sony NWZ-E473 Battery Replacement: 步骤 5 中的图像 2,3 Sony NWZ-E473 Battery Replacement: 步骤 5 中的图像 3,3
    • Remove the back plate from the device.
  6. Sony NWZ-E473 Battery Replacement, Battery: 步骤 6 中的图像 1,2 Sony NWZ-E473 Battery Replacement, Battery: 步骤 6 中的图像 2,2
    • Peel back the layer of tape along with the processor, which is located just below the battery, using the tweezers and the spudger.
  7. Sony NWZ-E473 Battery Replacement: 步骤 7 中的图像 1,2 Sony NWZ-E473 Battery Replacement: 步骤 7 中的图像 2,2
    • Slide a prying tool underneath the top portion of the battery and lift it from the case.
  8. Sony NWZ-E473 Battery Replacement: 步骤 8 中的图像 1,1
    • Remove the stickers from the battery terminals, which are on the underside of the battery.
  9. Sony NWZ-E473 Battery Replacement: 步骤 9 中的图像 1,1
    • Use a soldering iron to remove the wires from the red and the black terminals.
结论
4等其他人完成本指南。
Matthew Hintz
于01/16/15注册
327 声望
创作了3篇指南
团队
USF Tampa, Team 17-6, Watkins Winter 2015 USF Tampa, Team 17-6, Watkins Winter 2015 的会员
USFT-WATKINS-W15S17G6
4 名成员
创作了5篇指南
2条评论
Hi their I have a Sony nwz-e355 walkman I want to replace the battery in it cause I thinks it's done I see u do a replacement for the e473 wondering if u have e355 batteries or will this e473 battery work in my walkman both need to be soildered in any feed back would help
Derek Hebert - 回复
I have the same model. I have 2 of them purchased years ago from Ubid.com. A very cool device. SONY ought to service them when the batteries fade…
guy lewit -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 37
总计 9,507
