跳转到主内容
Sony NEX-7 Battery Replacement
  1. Sony NEX-7 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Sony NEX-7 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
    • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
  2. Sony NEX-7 Battery Replacement: 步骤 2 中的图像 1,1
    • Flip the camera over such that the power switch points down.
    • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
  3. Sony NEX-7 Battery Replacement: 步骤 3 中的图像 1,1
    • With the battery door open, push the blue lever in the battery compartment to release the battery.
结论
To replace the battery, fit it in the slot, then close and lock the door.
2等其他人完成本指南。
Tyler
于04/22/14注册
569 声望
撰写一个指南
团队
Cal Poly, Team 10-55, Amido Spring 2014 Cal Poly, Team 10-55, Amido Spring 2014 的会员
CPSU-AMIDO-S14S10G55
4 名成员
创作了31篇指南
一条评论
I’ve done this about a million times. :)
Martin Hurley - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 2,036
