跳转到主内容
Sony NEX-5T SD Card Replacement
你所需要的
  1. Sony NEX-5T SD Card Replacement, SD Card: 步骤 1 中的图像 1,3 Sony NEX-5T SD Card Replacement, SD Card: 步骤 1 中的图像 2,3 Sony NEX-5T SD Card Replacement, SD Card: 步骤 1 中的图像 3,3
    • Make sure to turn the cameras power switch to off before beginning this step.
    • Begin by holding the camera upside down with the bottom facing you. Identify the housing for the SD card, and battery.
    • You will use your other hand to slide the lock switch to this housing to the right. This will release the cap, allow it to come upwards.
  2. Sony NEX-5T SD Card Replacement: 步骤 2 中的图像 1,3 Sony NEX-5T SD Card Replacement: 步骤 2 中的图像 2,3 Sony NEX-5T SD Card Replacement: 步骤 2 中的图像 3,3
    • Now that the cap to the battery and SD card housing is open, the SD card is visible.
    • You will need to press down on the SD card until you hear a click. Release the SD card and it will now be available to remove.
    • Grip the SD card and pull it out of the SD card slot.
  3. Sony NEX-5T SD Card Replacement: 步骤 3 中的图像 1,3 Sony NEX-5T SD Card Replacement: 步骤 3 中的图像 2,3 Sony NEX-5T SD Card Replacement: 步骤 3 中的图像 3,3
    • To reinsert the SD card place it in its housing.
    • You will then need to push down on the SD card until you hear a click.
    • To ensure the SD card is in place you can visually inspect it. The SD card should be flush with the housing.
  4. Sony NEX-5T SD Card Replacement: 步骤 4 中的图像 1,3 Sony NEX-5T SD Card Replacement: 步骤 4 中的图像 2,3 Sony NEX-5T SD Card Replacement: 步骤 4 中的图像 3,3
    • You may now close the housing for the SD card and battery.
    • Close the cap and while holding it down slide the locking tab to the left. This step should lock the cap in place.
    • Your SD card is now safely in place and you may turn your device on.
终点
Robert Phillips
于03/02/17注册
321 声望
创作了2篇指南
团队
USF Tampa, Team S13-G2, Cagle Spring 2017 USF Tampa, Team S13-G2, Cagle Spring 2017 的会员
USFT-CAGLE-S17S13G2
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 23
总计 866
