跳转到主内容
Sony NEX-5T LCD Screen Replacement
你所需要的
  1. Sony NEX-5T LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Open the battery compartment by sliding the lock to the right.
  2. Sony NEX-5T LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Push in the blue lever.
    • The battery is on a spring so make sure you have control over it, or it might fly out.
  3. Sony NEX-5T LCD Screen Replacement: 步骤 3 中的图像 1,2 Sony NEX-5T LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Pull the battery out.
  4. Sony NEX-5T LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 1,2 Sony NEX-5T LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 2,2
    • Pick up the device with the LCD screen facing you.
    • While gripping with one hand, lift up on the LCD screen to reveal screws underneath
  5. Sony NEX-5T LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Unscrew and remove the eight1.2mm Phillips 00 screws.
    • Make sure to apply adequate pressure while unscrewing these screws to avoid stripping them.
    • Removing these screws will loosen the plates which cover the LCD screen.
  6. Sony NEX-5T LCD Screen Replacement: 步骤 6 中的图像 1,2 Sony NEX-5T LCD Screen Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove the black plate by using your fingers or tweezers.
    • This plate may be difficult to remove. Try to manipulate the position of the screen in order to make removal easier.
  7. Sony NEX-5T LCD Screen Replacement: 步骤 7 中的图像 1,3 Sony NEX-5T LCD Screen Replacement: 步骤 7 中的图像 2,3 Sony NEX-5T LCD Screen Replacement: 步骤 7 中的图像 3,3
    • Remove the second plate by pulling it away from the camera. You can use tweezers or your fingers for this step.
  8. Sony NEX-5T LCD Screen Replacement: 步骤 8 中的图像 1,3 Sony NEX-5T LCD Screen Replacement: 步骤 8 中的图像 2,3 Sony NEX-5T LCD Screen Replacement: 步骤 8 中的图像 3,3
    • Rotate the camera so the lens is facedown and the power button is pointing away from you.
    • Remove the two 1.2mm Phillips 00 screws shown in the image.
  9. Sony NEX-5T LCD Screen Replacement: 步骤 9 中的图像 1,2 Sony NEX-5T LCD Screen Replacement: 步骤 9 中的图像 2,2
    • Remove the 2 metal side coverings from the side of the LCD.
    • You may have to manipulate the position of the LCD screen to allow easier removal.
  10. Sony NEX-5T LCD Screen Replacement: 步骤 10 中的图像 1,3 Sony NEX-5T LCD Screen Replacement: 步骤 10 中的图像 2,3 Sony NEX-5T LCD Screen Replacement: 步骤 10 中的图像 3,3
    • Use tweezers to peel back the small black film.
  11. Sony NEX-5T LCD Screen Replacement: 步骤 11 中的图像 1,3 Sony NEX-5T LCD Screen Replacement: 步骤 11 中的图像 2,3 Sony NEX-5T LCD Screen Replacement: 步骤 11 中的图像 3,3
    • Rotate the camera, and lift up on the LCD screen.
    • Be careful you do not pull the LCD too far from the camera because wires are still attached.
    • This will reveal a large black rectangular film which you can peel back with tweezers.
  12. Sony NEX-5T LCD Screen Replacement: 步骤 12 中的图像 1,3 Sony NEX-5T LCD Screen Replacement: 步骤 12 中的图像 2,3 Sony NEX-5T LCD Screen Replacement: 步骤 12 中的图像 3,3
    • Rotate the camera and use your fingers or tweezers to disconnect the first wire.
    • Remove the wire gently to avoid damage.
  13. Sony NEX-5T LCD Screen Replacement: 步骤 13 中的图像 1,3 Sony NEX-5T LCD Screen Replacement: 步骤 13 中的图像 2,3 Sony NEX-5T LCD Screen Replacement: 步骤 13 中的图像 3,3
    • Lift the tab of the ZIF connector and pull the wire away from the motherboard.
  14. Sony NEX-5T LCD Screen Replacement: 步骤 14 中的图像 1,1
    • You may remove the loose black film from the back of the LCD screen.
    • When purchasing a new LCD screen be mindful that some do not come with the original plastic frame. You may have to separate these pieces by pushing the LCD out of the frame from behind.
    • It takes force to break the adhesive bond, but be mindful to not break the frame when applying force.
    • Upon reassembly place the tape on the inner edges of the LCD frame. When pressed back together there may be excess, use a knife to remove this overlap.
结论
5等其他人完成本指南。
Robert Phillips
于03/02/17注册
321 声望
创作了2篇指南
团队
USF Tampa, Team S13-G2, Cagle Spring 2017 USF Tampa, Team S13-G2, Cagle Spring 2017 的会员
USFT-CAGLE-S17S13G2
3 名成员
创作了12篇指南
3条评论
Where does one find the replacement screen? I’m in sore need of this myself.
Will Evans - 回复
I was able to get the screen working with a new replacement, but without the double-sided tape it feels like a cludge.
Will Evans - 回复
where did you find the screen, if i may?
Haziq Husni -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 40
总计 3,208
