跳转到主内容
Sony NEX-5R Main Navigation Button Replacement
你所需要的
  1. Sony NEX-5R Main Navigation Button Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
  2. Sony NEX-5R Main Navigation Button Replacement: 步骤 2 中的图像 1,1
    • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
  3. Sony NEX-5R Main Navigation Button Replacement: 步骤 3 中的图像 1,1
    • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
  4. Sony NEX-5R Main Navigation Button Replacement: 步骤 4 中的图像 1,1
    • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
  5. Sony NEX-5R Main Navigation Button Replacement: 步骤 5 中的图像 1,2 Sony NEX-5R Main Navigation Button Replacement: 步骤 5 中的图像 2,2
    • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
    • The back frame is fragile, so use the spudger gently.
  6. Sony NEX-5R Main Navigation Button Replacement: 步骤 6 中的图像 1,1
    • The back case should now be removed and look like this.
  7. Sony NEX-5R Main Navigation Button Replacement, Main Navigation Button: 步骤 7 中的图像 1,1
    • Use spudger to pull the lead out from its housing.
  8. Sony NEX-5R Main Navigation Button Replacement: 步骤 8 中的图像 1,2 Sony NEX-5R Main Navigation Button Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    • Squeeze the lead with the tweezers and hold the lead teeth tightly with your fingers. Pull straight out to disconnect.
  9. Sony NEX-5R Main Navigation Button Replacement: 步骤 9 中的图像 1,2 Sony NEX-5R Main Navigation Button Replacement: 步骤 9 中的图像 2,2
    • The navigation button component should now be separate and able to be replaced with new component. The camera and navigation button should appear as shown.
结论
3等其他人完成本指南。
Emily Trujillo
于04/08/14注册
1,153 声望
创作了6篇指南
团队
Cal Poly, Team 8-9, Regan Spring 2014 Cal Poly, Team 8-9, Regan Spring 2014 的会员
CPSU-REGAN-S14S8G9
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 41
总计 4,569
