跳转到主内容
Sony MVC-FD200 Back Cover Replacement
你所需要的
  1. Sony MVC-FD200 Back Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • Using your finger, slide the tab on the battery door up to release the battery latch.
  2. Sony MVC-FD200 Back Cover Replacement: 步骤 2 中的图像 1,1
    • Lift the battery door to reveal the battery compartment.
    • Push the gray lever to the left side to remove the battery.
    • If any other repairs are needed, make sure to carefully remove the battery to avoid any electric shock or short circuits during repairs.
  3. Sony MVC-FD200 Back Cover Replacement, Back Cover: 步骤 3 中的图像 1,1
    • Turn the camera so that the top is facing down towards the table.
    • Using the Phillips #00 screwdriver, remove all 2.0 mm screws with the arrows facing towards them.
  4. Sony MVC-FD200 Back Cover Replacement: 步骤 4 中的图像 1,2 Sony MVC-FD200 Back Cover Replacement: 步骤 4 中的图像 2,2
    • Flip the camera on both sides and remove the rest of the screws with arrows facing towards them.
    • Remove the 2.0 mm screws with the Phillips #00 screwdriver for both sides of the camera.
结论
Kobe Rodriguez
于03/21/25注册
366 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-4, Rioux Spring 2025 UMass Dartmouth, Team 1-4, Rioux Spring 2025 的会员
UMASSD-RIOUX-S25S1G4
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 102
