跳转到主内容
Sony M-430 Microcassette-Corder Speaker Replacement
你所需要的
  1. Sony M-430 Microcassette-Corder Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Find the arrow on the battery cover on the back of the device.
    • While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
  2. Sony M-430 Microcassette-Corder Speaker Replacement: 步骤 2 中的图像 1,2 Sony M-430 Microcassette-Corder Speaker Replacement: 步骤 2 中的图像 2,2
    • Lift the cover and remove the batteries.
  3. Sony M-430 Microcassette-Corder Speaker Replacement, Back Cover: 步骤 3 中的图像 1,2 Sony M-430 Microcassette-Corder Speaker Replacement, Back Cover: 步骤 3 中的图像 2,2
    • Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
    • Next, twist it to the side as shown in the second picture. The lid should simply snap off.
    • Be careful not to apply too much force, as the lid may break.
  4. Sony M-430 Microcassette-Corder Speaker Replacement: 步骤 4 中的图像 1,2 Sony M-430 Microcassette-Corder Speaker Replacement: 步骤 4 中的图像 2,2
    • Use a #00 Phillips head screwdriver to remove the four (1.7x16 mm) screws from the back case.
    • Next, use the same screwdriver to unscrew the (1.7X5 mm) screw, which is located inside the battery compartment.
  5. Sony M-430 Microcassette-Corder Speaker Replacement: 步骤 5 中的图像 1,1
    • Use a spudger to push in the two tabs located on the bottom of the device.
    • It works best to push the tabs at an upward angle (towards the top of the battery compartment)
    • It may take a decent amount of force in order to push in the tabs.
  6. Sony M-430 Microcassette-Corder Speaker Replacement: 步骤 6 中的图像 1,1
    • With a firm grip on the larger half, remove the back cover by lifting first on the battery area.
    • The back cover should lift cleanly off.
  7. Sony M-430 Microcassette-Corder Speaker Replacement, Speaker: 步骤 7 中的图像 1,1
    • The speaker is the large gold circular piece attached under where the batteries would normally be.
    • It is connected to the device with two black wires that run along one side of the motherboard, as shown on the top of the picture.
  8. Sony M-430 Microcassette-Corder Speaker Replacement: 步骤 8 中的图像 1,2 Sony M-430 Microcassette-Corder Speaker Replacement: 步骤 8 中的图像 2,2
    • Depending on the replacement speaker you have, there are two places you can desolder the wire.
    • If your replacement speaker has a wire already attached to it, desolder the old wire from where it connects to the motherboard.
    • If the replacement speaker has no wire, desolder the old wire where it connects to the broken speaker.
  9. Sony M-430 Microcassette-Corder Speaker Replacement: 步骤 9 中的图像 1,2 Sony M-430 Microcassette-Corder Speaker Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Unscrew the 2 Phillips head screws (2x2.5 mm) around the edge of the speaker with a #00 Phillips screwdriver.
    • Use a pair of tweezers to remove the black tape on the speaker. Put the tape on the back of the new speaker.
  10. Sony M-430 Microcassette-Corder Speaker Replacement: 步骤 10 中的图像 1,1
    • Now that the speaker is detached from the device, simply tilt the device over and let the speaker fall out.
结论
Matt Teare
于01/20/12注册
35 声望
创作了3篇指南
团队
Cal Poly, Team 10-34, Amido Winter 2012 Cal Poly, Team 10-34, Amido Winter 2012 的会员
CPSU-AMIDO-W12S10G34
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 28
总计 898
