跳转到主内容
你所需要的
  1. Sony M-430 Microcassette-Corder Back Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • Find the arrow on the battery cover on the back of the device.
    • While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
  2. Sony M-430 Microcassette-Corder Back Cover Replacement: 步骤 2 中的图像 1,2 Sony M-430 Microcassette-Corder Back Cover Replacement: 步骤 2 中的图像 2,2
    • Lift the cover and remove the batteries.
  3. Sony M-430 Microcassette-Corder Back Cover Replacement, Back Cover: 步骤 3 中的图像 1,2 Sony M-430 Microcassette-Corder Back Cover Replacement, Back Cover: 步骤 3 中的图像 2,2
    • Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
    • Next, twist it to the side as shown in the second picture. The lid should simply snap off.
    • Be careful not to apply too much force, as the lid may break.
  4. Sony M-430 Microcassette-Corder Back Cover Replacement: 步骤 4 中的图像 1,2 Sony M-430 Microcassette-Corder Back Cover Replacement: 步骤 4 中的图像 2,2
    • Use a #00 Phillips head screwdriver to remove the four (1.7x16 mm) screws from the back case.
    • Next, use the same screwdriver to unscrew the (1.7X5 mm) screw, which is located inside the battery compartment.
  5. Sony M-430 Microcassette-Corder Back Cover Replacement: 步骤 5 中的图像 1,1
    • Use a spudger to push in the two tabs located on the bottom of the device.
    • It works best to push the tabs at an upward angle (towards the top of the battery compartment)
    • It may take a decent amount of force in order to push in the tabs.
  6. Sony M-430 Microcassette-Corder Back Cover Replacement: 步骤 6 中的图像 1,1
    • With a firm grip on the larger half, remove the back cover by lifting first on the battery area.
    • The back cover should lift cleanly off.
结论
另外一个人完成了本指南。
Matt Teare
于2012年01月20日注册
35 声望
创作了3篇指南
团队
Cal Poly, Team 10-34, Amido Winter 2012 Cal Poly, Team 10-34, Amido Winter 2012 的会员
CPSU-AMIDO-W12S10G34
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 1,843
