跳转到主内容
加入维修社区 - 创建账户
此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论
Sony ICFC1T 电池更换
你所需要的
    1. Sony ICFC1T 电池更换, 电池: 步骤 1 中的图像 1,2 Sony ICFC1T 电池更换, 电池: 步骤 1 中的图像 2,2
      • 从设备底部拆下电池仓。
      • 用拇指和食指捏住拉片,轻轻拉动直到电池仓松开。
      • 在处理设备前,请务必确保已拔掉电源,以防触电。
      询问修复机器人
      添加评论
    2. Sony ICFC1T 电池更换: 步骤 2 中的图像 1,1
      • 从电池仓标有 “PUSH” 的一侧按压,取出旧电池,然后放入新电池,正极朝上。
      添加评论
    3. Sony ICFC1T 电池更换: 步骤 3 中的图像 1,1
      • 将电池仓装回设备底部。
      • 重新设置时钟的时间。
      • 插上时钟电源,这样就不必依赖备用电池了。
      添加评论
结论
要重新组装设备,请按相反顺序执行这些说明。
取消:我没有完成这个指南。
3等其他人完成本指南。
9指南评论
Thank you so much for creating this. :)
LadyLion - 回复 分享
step 2--I can't get the battery out of the compartment. Am I not pushing hard enough? Should I take a screw driver to pry it out? I'm afraid of breaking the compartment since it's only plastic.
Iris - 回复 分享
The battery does not prevent the display/clock from switching off when I unplug the cord. Is the purpose of the battery not supposed to be to retain power even when unplugged? I have already put in a replacement one, presuming the one that came with it to be faulty. How do I get this to work?
Is the original Sony one meant to charge up or something? Please help as it doesn’t seem right if back up battery function does not do it’s job.
KIRSTY MCNICOL - 回复 分享
The back up battery doesn’t seem to do it’s job. Unit switches off when unplugged. Is it the case that the original Sony battery charges? I assumed ut to be flat, replaced the battery but this doesn’t retain the power either
Is my clock faulty? How to engage the back-up battery?
@kirstyonline Kirsty, as the battery description says, it is only backup. So not for full device powering, but only to back-up time status while mains power is down. Unfortunately, this device is only capable of running from mains.
Radoslav Gulik - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 53
过去 30 天: 166
总计 18,809
