跳转到主内容
Sony ICF-P26 Antenna Replacement
你所需要的
  1. Sony ICF-P26 Antenna Replacement, Antenna: 步骤 1 中的图像 1,2 Sony ICF-P26 Antenna Replacement, Antenna: 步骤 1 中的图像 2,2
    • Power off and disconnect the radio from any power source.
  2. Sony ICF-P26 Antenna Replacement: 步骤 2 中的图像 1,3 Sony ICF-P26 Antenna Replacement: 步骤 2 中的图像 2,3 Sony ICF-P26 Antenna Replacement: 步骤 2 中的图像 3,3
    • Use a mini screwdriver to remove the two screws from the battery compartment.
    • Gently insert an opening tool where the FM/AM/Off switch is, to force your way up.
    • Insert the opening tool in the other side where the volume and the earphone go.
    • You will hear hinges pop open.
  3. Sony ICF-P26 Antenna Replacement: 步骤 3 中的图像 1,3 Sony ICF-P26 Antenna Replacement: 步骤 3 中的图像 2,3 Sony ICF-P26 Antenna Replacement: 步骤 3 中的图像 3,3
    • Use the mini screwdriver to remove the screw holding the motherboard.
    • Unscrew the damaged antenna.
  4. Sony ICF-P26 Antenna Replacement: 步骤 4 中的图像 1,3 Sony ICF-P26 Antenna Replacement: 步骤 4 中的图像 2,3 Sony ICF-P26 Antenna Replacement: 步骤 4 中的图像 3,3
    • Use the mini screwdriver to replace the new antenna.
  5. Sony ICF-P26 Antenna Replacement: 步骤 5 中的图像 1,2 Sony ICF-P26 Antenna Replacement: 步骤 5 中的图像 2,2
    • Use the mini screwdriver to assemble the motherboard.
  6. Sony ICF-P26 Antenna Replacement: 步骤 6 中的图像 1,3 Sony ICF-P26 Antenna Replacement: 步骤 6 中的图像 2,3 Sony ICF-P26 Antenna Replacement: 步骤 6 中的图像 3,3
    • Use the mini screwdriver to assemble the cover.
    • Insert the batteries.
  7. Sony ICF-P26 Antenna Replacement: 步骤 7 中的图像 1,2 Sony ICF-P26 Antenna Replacement: 步骤 7 中的图像 2,2
    • Switch on the radio.
终点
4等其他人完成本指南。
团队
2条评论
Where would one acquire a compatible replacement antenna for this model of radio?
Mason Smith - 回复
Thank you so much. The difficulty is opening the case. You explained it very well. My problem was the dirty potentiometer. I simply poured enough isopropyl alcool on it, to "wash" it, it flowed inside, turn it few times, that was all. Works as new. Thank you.
Jean-Yves Béguec - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 23
过去 30 天: 74
总计 3,632
