跳转到主内容
Sony ICF-C1T Volume Dial Replacement
你所需要的
  1. Sony ICF-C1T Volume Dial Replacement, Volume Dial: 步骤 1 中的图像 1,1
    • Remove the 4 (14mm) screws from the underside of the device using the Philips #0 Screwdriver.
    • Before beginning this step, make sure the clock is unplugged and the batteries have been removed.
  2. Sony ICF-C1T Volume Dial Replacement: 步骤 2 中的图像 1,1
    • Pry apart the edge of the top and side portions of the device using a flat-headed tool (i.e. flathead screwdriver, card, etc)
    • It is recommended to use the iFixit Opening Tools for optimal removal.
  3. Sony ICF-C1T Volume Dial Replacement: 步骤 3 中的图像 1,2 Sony ICF-C1T Volume Dial Replacement: 步骤 3 中的图像 2,2
    • Carefully separate the device by gently pulling up on the top of the clock/radio.
    • Use caution when pulling the top of the clock; the clock display is located directly behind the faceplate and still connected by multiple wires.
  4. Sony ICF-C1T Volume Dial Replacement: 步骤 4 中的图像 1,2 Sony ICF-C1T Volume Dial Replacement: 步骤 4 中的图像 2,2
    • To remove the motherboard, gently pull apart the sides of the device.
    • Do not pull hard on the motherboard, as it is still connected by multiple wires inside the device.
    • Be careful of sharp pieces.
    • It would be helpful, although not necessary, to have someone helping out with this step.
  5. Sony ICF-C1T Volume Dial Replacement: 步骤 5 中的图像 1,2 Sony ICF-C1T Volume Dial Replacement: 步骤 5 中的图像 2,2
    • Remove the volume dial by pulling it off the motherboard. This can take a little force to remove.
结论
1指南评论
thanks for the great instructions. a few notes: it seems the “edit” comments were all left in above (“no edits necessary” and the stuff about highlighting parts of it). after step 3, there wasn’t instructions about removing the two screws from the motherboard, before step 4.
J Kwan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 1,534
