跳转到主内容
加入维修社区 - 创建账户
Sony ICF-C1T Speaker Replacement
你所需要的
  1. Sony ICF-C1T Speaker Replacement, Speaker: 步骤 1 中的图像 1,2 Sony ICF-C1T Speaker Replacement, Speaker: 步骤 1 中的图像 2,2
    • Locate the underside of the device. Use the Phillips #00 screwdriver to remove the four 14mm screws.
    • Be sure that the device is unplugged and the battery has been removed before tampering with the device.
  2. Sony ICF-C1T Speaker Replacement: 步骤 2 中的图像 1,1
    • Locate where the top-side of the speaker connects with the sides and use the iFixit Opening Tool to gently pry the top-side off.
  3. Sony ICF-C1T Speaker Replacement: 步骤 3 中的图像 1,2 Sony ICF-C1T Speaker Replacement: 步骤 3 中的图像 2,2
    • Gently pull the top of the clock away from the rest of the device.
    • Be careful when tugging on this piece of the clock. The clock display is located directly inside the front face and is connected by multiple wires.
  4. Sony ICF-C1T Speaker Replacement: 步骤 4 中的图像 1,2 Sony ICF-C1T Speaker Replacement: 步骤 4 中的图像 2,2
    • Using the Phillips #00 screwdriver, remove the two 14mm screws from the top of the motherboard.
    • Be careful to avoid the sharp pieces on the motherboard when handling the device.
  5. Sony ICF-C1T Speaker Replacement: 步骤 5 中的图像 1,3 Sony ICF-C1T Speaker Replacement: 步骤 5 中的图像 2,3 Sony ICF-C1T Speaker Replacement: 步骤 5 中的图像 3,3
    • Remove the Phillips #00 screw from the bottom of the white and blue box.
    • Remove the Phillips #00 screw from behind the white and blue box.
    • After unscrewing the white box, gently pull it out. This will allow for more room to access the speaker.
  6. Sony ICF-C1T Speaker Replacement: 步骤 6 中的图像 1,1
    • To separate the motherboard completely, you can cut the red and black wires that are attached to the speaker. This will allow you to access the speaker fully.
    • Use caution when tampering with the wires and sharp parts of the device.
  7. Sony ICF-C1T Speaker Replacement: 步骤 7 中的图像 1,2 Sony ICF-C1T Speaker Replacement: 步骤 7 中的图像 2,2
    • Use the plastic opening tool and the spudger to separate the speaker from the device by tracing its outline and loosening the glue.
    • Do this step gently as to not damage the device or cause harm to yourself.
    • When reassembling the device, you will need to use glue to place the new speaker back in its place.
    • It would be wise to test the device after reconnecting wires, before screwing and gluing the parts back together.
结论
另外一个人完成了本指南。
1指南评论
can I connect aux out port to speaker?
Dong-Hwan Shin - 回复 Share
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 36
总计 3,117
