跳转到主内容
加入维修社区 - 创建账户
Sony ICF-C1T Screen Replacement
你所需要的
  1. Sony ICF-C1T Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Make sure the clock is unplugged from the wall and the replacement battery has been taken out of the clock to prevent harm to you and to the clock.
    • Use a Phillips 00 head screwdriver to remove the four 14 mm screws from the bottom of the clock.
  2. Sony ICF-C1T Screen Replacement: 步骤 2 中的图像 1,1
    • Insert the plastic opening tool to pry apart the top and sides of the device gently.
  3. Sony ICF-C1T Screen Replacement: 步骤 3 中的图像 1,2 Sony ICF-C1T Screen Replacement: 步骤 3 中的图像 2,2
    • Carefully pull the top of clock off as the clock display is located directly behind the face plate and is still connected by multiple wires.
    • Pull the top of the device away from the rest of the clock to expose the inside.
  4. Sony ICF-C1T Screen Replacement: 步骤 4 中的图像 1,2 Sony ICF-C1T Screen Replacement: 步骤 4 中的图像 2,2
    • Do not use too much pressure on the plastic to not break it.
    • Add pressure to the inside of the screen so that a small area is loosened enough to be able to use an opening tool.
    • Use the plastic opening tool to separate the screen from the device.
  5. Sony ICF-C1T Screen Replacement: 步骤 5 中的图像 1,2 Sony ICF-C1T Screen Replacement: 步骤 5 中的图像 2,2
    • Apply a tinted spray to dim the brightness once the tinted sheet is out of the way.
    • Another way to solve the brightness problem is to apply a tinted color sheet protector.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 40
总计 5,373
