简介
Before throwing your defunct drive in the freezer or hitting it like the Fonz in the hopes that it will magically work again, follow this replacement guide. Be sure to conduct your repairs in a Class-100 clean room (less than 100 particles of dust per square foot of air) to prevent internal contamination and have some sort of container prepared to save your screws.
你所需要的
Start at the bottom of the camera, where the threaded tripod mount is. There you will find two screws securing a plastic panel, one next to the Sony logo and the other under the push tab.
Remove the two 3mm Phillips #00 screws from this panel. Note that all screws mentioned in this assembly are 3mm Phillips #00 screws and thus only one tool is needed for this replacement.
To reassemble your device, follow these instructions in reverse order. Be sure to test your camcorder after assembly to ensure the new disk drive is compatible and operational.
4等其他人完成本指南。
2条评论
My HD is fine so far but always wondered what I would do if it died. Thank You
