跳转到主内容
Sony Handycam HDR-XR500V Door Replacement
你所需要的
  1. Sony Handycam HDR-XR500V Door Replacement, Opening LCD screen: 步骤 1 中的图像 1,2 Sony Handycam HDR-XR500V Door Replacement, Opening LCD screen: 步骤 1 中的图像 2,2
    • Pull on tab away from the camera by applying pressure with index finger.
  2. Sony Handycam HDR-XR500V Door Replacement: 步骤 2 中的图像 1,1
    • Next, remove the three 3 screws shown with the red markers.
  3. Sony Handycam HDR-XR500V Door Replacement: 步骤 3 中的图像 1,3 Sony Handycam HDR-XR500V Door Replacement: 步骤 3 中的图像 2,3 Sony Handycam HDR-XR500V Door Replacement: 步骤 3 中的图像 3,3
    • Place the camera on a flat service, so that the strap is downward and the lens is facing you.
    • First, lift up the connector.
    • Then pull it back.
    • Remove the connector from the device.
  4. Sony Handycam HDR-XR500V Door Replacement: 步骤 4 中的图像 1,2 Sony Handycam HDR-XR500V Door Replacement: 步骤 4 中的图像 2,2
    • Position the camera so that the screen tab is pointing towards you.
    • Twist the tab clockwise one notch.
    • Remove the single screw.
  5. Sony Handycam HDR-XR500V Door Replacement: 步骤 5 中的图像 1,1
    • Remove the two screws on the control board.
  6. Sony Handycam HDR-XR500V Door Replacement: 步骤 6 中的图像 1,2 Sony Handycam HDR-XR500V Door Replacement: 步骤 6 中的图像 2,2
    • Place the camera so that the lens is facing downward and the battery compartment is facing towards you.
  7. Sony Handycam HDR-XR500V Door Replacement: 步骤 7 中的图像 1,1
    • Lay the device on its side so it is resting on the strap and the bottom of the camera is facing you.
    • Remove the five screws.
  8. Sony Handycam HDR-XR500V Door Replacement: 步骤 8 中的图像 1,1
    • Close the LCD screen door.
    • Turn the camera to the eye piece and battery compartment is facing you.
  9. Sony Handycam HDR-XR500V Door Replacement: 步骤 9 中的图像 1,1
    • Pull the entire cabinet panel away from camera.
  10. Sony Handycam HDR-XR500V Door Replacement: 步骤 10 中的图像 1,1
    • You have disassembled the cabinet door and got to the speakers.
    • Do not try to pry off the entire door, it can remain slightly attached.
结论
Your door will now be disassembled in order to replace parts inside and these steps in reverse order will also help you put the door back together
Amber Han
于09/09/14注册
113 声望
撰写一个指南
团队
CSU Fullerton, Team 2-5, Bruce Fall 2014 CSU Fullerton, Team 2-5, Bruce Fall 2014 的会员
CSUF-BRUCE-F14S2G5
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 801
