跳转到主内容
Sony Handycam HDR-CX675 Lens Cover Panel Replacement
你所需要的
  1. Sony Handycam HDR-CX675 Lens Cover Panel Replacement, Camera Shell: 步骤 1 中的图像 1,1
    • The battery should be removed and oriented upwards.
  2. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: 步骤 2 中的图像 1,1
    • Remove the side 4.5 mm JIS #00 screw using JIS Screwdriver
    • Remove the 5.5 mm JIS #00 screw.
  3. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: 步骤 3 中的图像 1,2 Sony Handycam HDR-CX675 Lens Cover Panel Replacement: 步骤 3 中的图像 2,2
    • Gently pry the plastic case surrounding the start/stop button free by using the blue plastic opening tools.
    • Remove the casing using your thumb and index finger.
  4. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: 步骤 4 中的图像 1,1
    • Turn the camera around and flip open the LCD screen to expose the side panel.
    • Remove the 5.5mm #00 screw using the J00 head screwdriver.
  5. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: 步骤 5 中的图像 1,1
    • Turn the camera to the handgrip side and unscrew two of the 5.5mm JIS #00 head screws using the JIS #00 head screwdriver.
  6. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: 步骤 6 中的图像 1,1
    • Remove the two 5.5mm JIS #00 screws with the bottom of the camera facing up.
  7. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: 步骤 7 中的图像 1,1
    • Turn the camera around in a way that the bottom of the camera is facing you.
    • Use the blue opening tool to gently remove the camera shell off of the camera.
  8. Sony Handycam HDR-CX675 Lens Cover Panel Replacement, Lens Cover Panel: 步骤 8 中的图像 1,1
    • Using the blue plastic opener smoothly to take the camera shell off.
  9. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: 步骤 9 中的图像 1,2 Sony Handycam HDR-CX675 Lens Cover Panel Replacement: 步骤 9 中的图像 2,2
    • Let the lens of the camera be pointed to your left.
    • Keep holding the camera with your right hand then gently remove the lens cover panel with your left hand.
结论
Laith Al Hinai
于02/15/17注册
161 声望
撰写一个指南
团队
USF Tampa, Team 8-2, Eyestone Spring 2017 USF Tampa, Team 8-2, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S8G2
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 13
总计 809
