跳转到主内容
Sony Handycam HDR-CX580V Lens Replacement
你所需要的
  1. Sony Handycam HDR-CX580V Lens Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the slider labeled "BATT" and pull it back from the battery with your thumb.
  2. Sony Handycam HDR-CX580V Lens Replacement: 步骤 2 中的图像 1,1
    • At this point, you should be able to remove the battery by simply lifting it from the camera.
    • The camera provided for guide-creation did not include a battery. However, the battery position should be the same.
  3. Sony Handycam HDR-CX580V Lens Replacement, Recording Button: 步骤 3 中的图像 1,3 Sony Handycam HDR-CX580V Lens Replacement, Recording Button: 步骤 3 中的图像 2,3 Sony Handycam HDR-CX580V Lens Replacement, Recording Button: 步骤 3 中的图像 3,3
    • Use the Phillips #00 head to remove the following 5.5mm screws on the left-hand side.
  4. Sony Handycam HDR-CX580V Lens Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the empty battery socket.
  5. Sony Handycam HDR-CX580V Lens Replacement: 步骤 5 中的图像 1,1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the bottom.
  6. Sony Handycam HDR-CX580V Lens Replacement: 步骤 6 中的图像 1,1
    • Fold back the hinging panel on the top of the camera located near the lens.
    • Use the Phillips #00 head to remove the following 5.5mm screws on the top under the hinging panel.
  7. Sony Handycam HDR-CX580V Lens Replacement: 步骤 7 中的图像 1,2 Sony Handycam HDR-CX580V Lens Replacement: 步骤 7 中的图像 2,2
    • Slide back the cover for the DC and A/V ports on the right-hand side.
    • Use the Phillips #00 head to remove the following 5.5mm screws underneath the cover and on the right-hand side.
  8. Sony Handycam HDR-CX580V Lens Replacement: 步骤 8 中的图像 1,1
    • Use the plastic opener tool to loosen the casing on the bottom and the right-hand side.
    • At this point, the right-hand side should simply come off, although it will still be connected with internal wiring.
    • Be delicate with the wiring still attached to the side casing until you have access to removing them later.
  9. Sony Handycam HDR-CX580V Lens Replacement: 步骤 9 中的图像 1,3 Sony Handycam HDR-CX580V Lens Replacement: 步骤 9 中的图像 2,3 Sony Handycam HDR-CX580V Lens Replacement: 步骤 9 中的图像 3,3
    • Carefully remove the bottom casing with your fingers.
    • Be careful not to loose the small metal stand-mount pieces that lay underneath the casing.
  10. Sony Handycam HDR-CX580V Lens Replacement: 步骤 10 中的图像 1,1
    • Look at the right side of the camera (the side with the recording button) while holding back the detached casing.
    • Use the Phillips #00 head to remove the following 5.5mm screws near the recording button.
  11. Sony Handycam HDR-CX580V Lens Replacement: 步骤 11 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use the curved tweezers to carefully detach the blue ribbon cable connector from the body of the camera.
    • The recording button and its blue ribbon cable connector should become detached from the body, but remain connected to the top casing.
  12. Sony Handycam HDR-CX580V Lens Replacement: 步骤 12 中的图像 1,2 Sony Handycam HDR-CX580V Lens Replacement: 步骤 12 中的图像 2,2
    • Pull off the top casing by lightly grabbing either side and pulling towards the back of the camera.
  13. Sony Handycam HDR-CX580V Lens Replacement: 步骤 13 中的图像 1,1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the inside of the top casing.
  14. Sony Handycam HDR-CX580V Lens Replacement: 步骤 14 中的图像 1,1
    • Carefully remove the metal frame from the top casing.
  15. Sony Handycam HDR-CX580V Lens Replacement: 步骤 15 中的图像 1,1
    • You are now free to remove the recording button, as well as its connection strip.
  16. Sony Handycam HDR-CX580V Lens Replacement, Lens: 步骤 16 中的图像 1,1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the right-hand side near the lens.
  17. Sony Handycam HDR-CX580V Lens Replacement: 步骤 17 中的图像 1,1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the top near the lens.
  18. Sony Handycam HDR-CX580V Lens Replacement: 步骤 18 中的图像 1,1
    • Carefully pop off the casing strip on the camera's left-hand side near the lens.
  19. Sony Handycam HDR-CX580V Lens Replacement: 步骤 19 中的图像 1,1
    • Use the Phillips #00 head to remove the following 5.5mm screws underneath the casing strip.
  20. Sony Handycam HDR-CX580V Lens Replacement: 步骤 20 中的图像 1,2 Sony Handycam HDR-CX580V Lens Replacement: 步骤 20 中的图像 2,2
    • Carefully pull the lens cover and shutter assembly off of the front of the camera.
    • Do not pull the the wires out too strongly. Be sure to remove them from their base where they attach to the camera's body.
  21. Sony Handycam HDR-CX580V Lens Replacement: 步骤 21 中的图像 1,1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the lens shell.
  22. Sony Handycam HDR-CX580V Lens Replacement: 步骤 22 中的图像 1,2 Sony Handycam HDR-CX580V Lens Replacement: 步骤 22 中的图像 2,2
    • Carefully remove the lens from the body of the camera.
    • Make sure to avoid touching the lens itself directly in order to prevent scratches or dirtying.
结论
Derek Fritz
于03/21/17注册
378 声望
创作了3篇指南
团队
Texas Tech, Team S46-G5, Bennett Spring 2017 Texas Tech, Team S46-G5, Bennett Spring 2017 的会员
TTU-BENNETT-S17S46G5
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 12
总计 547
