简介
You will learn how to remove the lens cover panel without damaging your device.
你所需要的
Rotate your camera such that the underside is facing you and the lens is facing the ground.
Orient the camera such that the lens is facing to your left.
Using your right hand to hold the camera, gently remove the lens panel from the camera with your left hand.
即将完成!
结论
另外一个人完成了本指南。
