跳转到主内容
Sony Handycam HDR-CX380 Camera Shell Replacement
你所需要的
  1. Sony Handycam HDR-CX380 Camera Shell Replacement, Battery: 步骤 1 中的图像 1,1
    • Rotate your camera such that the underside is facing you and the lens is facing the ground.
    • You should be able to see the camera's label, and it should be rotated 90 degrees counterclockwise.
  2. Sony Handycam HDR-CX380 Camera Shell Replacement: 步骤 2 中的图像 1,1
    • Using your left thumb, push down the slider to the left of the SD card slot.
    • When inserting a new battery or reinserting the one you removed, you can ignore this step.
  3. Sony Handycam HDR-CX380 Camera Shell Replacement: 步骤 3 中的图像 1,2 Sony Handycam HDR-CX380 Camera Shell Replacement: 步骤 3 中的图像 2,2
    • Using your right index finger and thumb, pull the battery toward you and then away from the camera.
  4. Sony Handycam HDR-CX380 Camera Shell Replacement, Camera Shell: 步骤 4 中的图像 1,1
    • Orient the camera with the battery side facing up.
  5. Sony Handycam HDR-CX380 Camera Shell Replacement: 步骤 5 中的图像 1,1
    • Remove the single 4.5 mm Phillips #00 screw.
    • Remove the single 5.5 mm Phillips #00 screw.
  6. Sony Handycam HDR-CX380 Camera Shell Replacement: 步骤 6 中的图像 1,2 Sony Handycam HDR-CX380 Camera Shell Replacement: 步骤 6 中的图像 2,2
    • With the blue plastic opening tools, gently pry the plastic casing surrounding the start/stop button free.
    • Remove the casing using your right thumb and index finger.
  7. Sony Handycam HDR-CX380 Camera Shell Replacement: 步骤 7 中的图像 1,1
    • Flip open the LCD panel to get to the side panel.
    • Remove the three 5.5 mm Phillips #00 screws.
  8. Sony Handycam HDR-CX380 Camera Shell Replacement: 步骤 8 中的图像 1,1
    • Turn the camera around to the grip side and remove the 5.5 mm Phillips Head screw using your J00 Phillips Head screwdriver.
  9. Sony Handycam HDR-CX380 Camera Shell Replacement: 步骤 9 中的图像 1,1
    • With the bottom of the camera facing up, remove the two 5.5mm Phillips #00 screws.
  10. Sony Handycam HDR-CX380 Camera Shell Replacement: 步骤 10 中的图像 1,2 Sony Handycam HDR-CX380 Camera Shell Replacement: 步骤 10 中的图像 2,2
    • Orient the camera so the bottom is facing you.
    • Use the blue plastic opening tools to gently ease the camera shell off of the camera.
    • Rotate the camera so the LCD side panel is facing you and gently pry the shell off from the camera.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 16-5, Blackwell Winter 2016 USF Tampa, Team 16-5, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S16G5
3 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 290
