跳转到主内容
Sony Handycam HDR-CX380 Battery Replacement
  1. Sony Handycam HDR-CX380 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Rotate your camera such that the underside is facing you and the lens is facing the ground.
    • You should be able to see the camera's label, and it should be rotated 90 degrees counterclockwise.
  2. Sony Handycam HDR-CX380 Battery Replacement: 步骤 2 中的图像 1,1
    • Using your left thumb, push down the slider to the left of the SD card slot.
    • When inserting a new battery or reinserting the one you removed, you can ignore this step.
  3. Sony Handycam HDR-CX380 Battery Replacement: 步骤 3 中的图像 1,2 Sony Handycam HDR-CX380 Battery Replacement: 步骤 3 中的图像 2,2
    • Using your right index finger and thumb, pull the battery toward you and then away from the camera.
结论
To insert a new battery or reinsert the one you removed, simply follow step 3 in reverse order and rotate the camera as described in step 1.
另外一个人完成了本指南。
John Santoro
于02/04/16注册
729 声望
创作了5篇指南
团队
USF Tampa, Team 16-5, Blackwell Winter 2016 USF Tampa, Team 16-5, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S16G5
3 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 553
