跳转到主内容
Sony Handycam HDR­-CX220 Motherboard Replacement
你所需要的
  1. Sony Handycam HDR­-CX220 Motherboard  Replacement, Battery: 步骤 1 中的图像 1,1
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Motherboard  Replacement: 步骤 2 中的图像 1,1
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Motherboard  Replacement, Camera's Body: 步骤 3 中的图像 1,3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Camera's Body: 步骤 3 中的图像 2,3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Camera's Body: 步骤 3 中的图像 3,3
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Motherboard  Replacement: 步骤 4 中的图像 1,3 Sony Handycam HDR­-CX220 Motherboard  Replacement: 步骤 4 中的图像 2,3 Sony Handycam HDR­-CX220 Motherboard  Replacement: 步骤 4 中的图像 3,3
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Motherboard  Replacement: 步骤 5 中的图像 1,1
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Motherboard  Replacement, Lens: 步骤 6 中的图像 1,3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Lens: 步骤 6 中的图像 2,3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Lens: 步骤 6 中的图像 3,3
    • Use the Phillips #0 Screwdriver to remove the 5mm screw
    • Use the Plastic Opening tools to unhook the highlighted area.
  7. Sony Handycam HDR­-CX220 Motherboard  Replacement: 步骤 7 中的图像 1,1
    • Remove the 3 (4mm) screws on the front of the lens using the Philips #0 Screwdriver.
  8. Sony Handycam HDR­-CX220 Motherboard  Replacement: 步骤 8 中的图像 1,1
    • Remove the lens and clean it if needed.
  9. Sony Handycam HDR­-CX220 Motherboard  Replacement, Motherboard: 步骤 9 中的图像 1,3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Motherboard: 步骤 9 中的图像 2,3 Sony Handycam HDR­-CX220 Motherboard  Replacement, Motherboard: 步骤 9 中的图像 3,3
    • Use the Phillips #0 Screwdriver to remove the shown 5mm screws.
    • Use the plastic opening tool to release the front hook.
    • Use the plastic opening tool to release the back hook.
  10. Sony Handycam HDR­-CX220 Motherboard  Replacement: 步骤 10 中的图像 1,2 Sony Handycam HDR­-CX220 Motherboard  Replacement: 步骤 10 中的图像 2,2
    • Gently pull on the 2 wires shown on the bottom of the camcorder.
    • Disconnect the wire shows on the second picture.
  11. Sony Handycam HDR­-CX220 Motherboard  Replacement: 步骤 11 中的图像 1,2 Sony Handycam HDR­-CX220 Motherboard  Replacement: 步骤 11 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove the 4mm screw shown.
    • Gently remove the motherboard with your fingers.
  12. Sony Handycam HDR­-CX220 Motherboard  Replacement: 步骤 12 中的图像 1,2 Sony Handycam HDR­-CX220 Motherboard  Replacement: 步骤 12 中的图像 2,2
    • Remove the side wire from the motherboard as shown on the photo.
    • Remove the top wire from the motherboard as shown on the photo.
  13. Sony Handycam HDR­-CX220 Motherboard  Replacement: 步骤 13 中的图像 1,2 Sony Handycam HDR­-CX220 Motherboard  Replacement: 步骤 13 中的图像 2,2
    • Unplug the speaker from the motherboard.
结论
另外一个人完成了本指南。
Keven
于03/11/16注册
811 声望
创作了6篇指南
团队
UMass Dartmouth, Team 8-5, Botvin Spring 2016 UMass Dartmouth, Team 8-5, Botvin Spring 2016 的会员
UMASSD-BOTVIN-S16S8G5
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 1,038
