跳转到主内容
Sony Handycam HDR­-CX220 Display Screen Replacement
你所需要的
  1. Sony Handycam HDR­-CX220 Display Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Display Screen Replacement: 步骤 2 中的图像 1,1
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: 步骤 3 中的图像 1,3 Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: 步骤 3 中的图像 2,3 Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: 步骤 3 中的图像 3,3
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Display Screen Replacement: 步骤 4 中的图像 1,3 Sony Handycam HDR­-CX220 Display Screen Replacement: 步骤 4 中的图像 2,3 Sony Handycam HDR­-CX220 Display Screen Replacement: 步骤 4 中的图像 3,3
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Display Screen Replacement: 步骤 5 中的图像 1,1
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Display Screen Replacement, Display Screen: 步骤 6 中的图像 1,2 Sony Handycam HDR­-CX220 Display Screen Replacement, Display Screen: 步骤 6 中的图像 2,2
    • Use the Phillips #0 screwdriver to remover the two (5mm) screws on the outer part and one (3mm) in the middle.
    • In the second image, there is a second screw on the opposite side of the screen hinge. This screw is not shown, but must also be removed.
  7. Sony Handycam HDR­-CX220 Display Screen Replacement: 步骤 7 中的图像 1,1
    • Use the plastic opening tool to remove the plastic case protecting the screen
    • Pull it gently not to damage anything under the case
  8. Sony Handycam HDR­-CX220 Display Screen Replacement: 步骤 8 中的图像 1,2 Sony Handycam HDR­-CX220 Display Screen Replacement: 步骤 8 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove the 2 screws shown
    • Use your hands to carefully unhook the screen from the highlighted hook
  9. Sony Handycam HDR­-CX220 Display Screen Replacement: 步骤 9 中的图像 1,3 Sony Handycam HDR­-CX220 Display Screen Replacement: 步骤 9 中的图像 2,3 Sony Handycam HDR­-CX220 Display Screen Replacement: 步骤 9 中的图像 3,3
    • Use your hands to carefully remove the tape
    • After removing the tape, pull on the wire disconnecting it from the screen.
结论
4等其他人完成本指南。
Keven
于03/11/16注册
811 声望
创作了6篇指南
团队
UMass Dartmouth, Team 8-5, Botvin Spring 2016 UMass Dartmouth, Team 8-5, Botvin Spring 2016 的会员
UMASSD-BOTVIN-S16S8G5
3 名成员
创作了12篇指南
3条评论
How do you mount hdr cx220 lcd cable flat? can you help me?
Rafael Oliveira - 回复
gjhgvnvyh n hygfv
ANM WORLD - 回复
We have a camera 220. Whose dipstick display strip has deteriorated again. Where can I find this strip? Video is good information so that's why
ANM WORLD - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 19
总计 2,490
