跳转到主内容
Sony Handycam FDR-AX33 Zoom and Photo Button Replacement
你所需要的
  1. Sony Handycam FDR-AX33 Zoom and Photo Button Replacement, Panel: 步骤 1 中的图像 1,2 Sony Handycam FDR-AX33 Zoom and Photo Button Replacement, Panel: 步骤 1 中的图像 2,2
    • Remove the battery by pushing the latch towards the body of the camera. Push the battery down and pull it out.
    • Remove the six black 4 mm Phillips #00 screws from the bottom panel of the camera.
    • Pull off the bottom panel. It may be difficult, but tugging on it shouldn't cause harm to yourself or the device.
    • Be sure to un-velcro the handle strap.
  2. Sony Handycam FDR-AX33 Zoom and Photo Button Replacement: 步骤 2 中的图像 1,3 Sony Handycam FDR-AX33 Zoom and Photo Button Replacement: 步骤 2 中的图像 2,3 Sony Handycam FDR-AX33 Zoom and Photo Button Replacement: 步骤 2 中的图像 3,3
    • Remove the 3 mm Phillips #00 screw from the bottom of the camera.
    • Remove the 4 mm Phillips #00 screw from the right panel.
    • Pull the right panel off. Again, it might be difficult, but pulling hard shouldn't harm you or the camera.
    • You may have to use the opening tool to remove this panel.
  3. Sony Handycam FDR-AX33 Zoom and Photo Button Replacement: 步骤 3 中的图像 1,2 Sony Handycam FDR-AX33 Zoom and Photo Button Replacement: 步骤 3 中的图像 2,2
    • Remove the two 4 mm Phillips #00 screws from the top right corner of the camera.
    • Remove the 4 mm Phillips #00 screw from in front of the flash mount.
  4. Sony Handycam FDR-AX33 Zoom and Photo Button Replacement: 步骤 4 中的图像 1,2 Sony Handycam FDR-AX33 Zoom and Photo Button Replacement: 步骤 4 中的图像 2,2
    • Remove the 3 mm Phillips #00 screw from below the right side of the battery slot.
    • Remove the black 5 mm Phillips #00 screw from the top of the battery slot.
  5. Sony Handycam FDR-AX33 Zoom and Photo Button Replacement: 步骤 5 中的图像 1,3 Sony Handycam FDR-AX33 Zoom and Photo Button Replacement: 步骤 5 中的图像 2,3 Sony Handycam FDR-AX33 Zoom and Photo Button Replacement: 步骤 5 中的图像 3,3
    • Remove the three 4 mm Phillips #00 screws from the left panel underneath the display screen.
    • You’ll need to extend the eyepiece by pulling it out from the body of the camera.
    • Pull the top panel off of the device with the iFixit opening tool.
  6. Sony Handycam FDR-AX33 Zoom and Photo Button Replacement: 步骤 6 中的图像 1,3 Sony Handycam FDR-AX33 Zoom and Photo Button Replacement: 步骤 6 中的图像 2,3 Sony Handycam FDR-AX33 Zoom and Photo Button Replacement: 步骤 6 中的图像 3,3
    • Remove the top and bottom 4 mm Phillips #00 screws from the display screen hinge.
    • Use the iFixit opening tool to remove the screen hinge.
  7. Sony Handycam FDR-AX33 Zoom and Photo Button Replacement: 步骤 7 中的图像 1,2 Sony Handycam FDR-AX33 Zoom and Photo Button Replacement: 步骤 7 中的图像 2,2
    • Remove the 3 mm Phillips #00 screw from between the eyepiece and the panel directly to the right of the battery slot.
    • Angle the eyepiece up to reach the screw with the screwdriver.
    • Take the panel directly to the right of the battery slot off of the camera.
  8. Sony Handycam FDR-AX33 Zoom and Photo Button Replacement: 步骤 8 中的图像 1,3 Sony Handycam FDR-AX33 Zoom and Photo Button Replacement: 步骤 8 中的图像 2,3 Sony Handycam FDR-AX33 Zoom and Photo Button Replacement: 步骤 8 中的图像 3,3
    • Remove the 4 mm Phillips #00 screw above and to the right of the battery slot.
    • Pry the left panel out at an angle by pushing the plastic slat between the battery slot and the eyepiece.
    • Wiggle the left panel and pull it out gently.
    • The left panel can be hard to remove so make sure to apply a good amount of force, but be cautious to not harm yourself or the device.
  9. Sony Handycam FDR-AX33 Zoom and Photo Button Replacement, Zoom, Photo, and Record Button: 步骤 9 中的图像 1,3 Sony Handycam FDR-AX33 Zoom and Photo Button Replacement, Zoom, Photo, and Record Button: 步骤 9 中的图像 2,3 Sony Handycam FDR-AX33 Zoom and Photo Button Replacement, Zoom, Photo, and Record Button: 步骤 9 中的图像 3,3
    • Remove the two 3 mm Phillips screws directly in front of the zoom button.
    • Slide the blue copper PCB out of the connector.
  10. Sony Handycam FDR-AX33 Zoom and Photo Button Replacement: 步骤 10 中的图像 1,2 Sony Handycam FDR-AX33 Zoom and Photo Button Replacement: 步骤 10 中的图像 2,2
    • Unclip the black plastic piece from behind the record button in order to remove the photo, record, and zoom buttons.
    • Use the black nylon spudger to remove the record button.
结论
Jacob Andreatta
于01/24/19注册
542 声望
创作了3篇指南
团队
Cal Poly, Team S18-G2, White Winter 2019 Cal Poly, Team S18-G2, White Winter 2019 的会员
CPSU-WHITE-W19S18G2
4 名成员
创作了12篇指南
1指南评论
Where can I buy the spare part?
Thanks
mattyvolins - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 935
