简介
This guide will help you replace the speaker if it isn't working right. This will require you to dismantle quite a bit, so make sure to place your screws in proper order so you can put it together again.
你所需要的
Remove the six black 4 mm Phillips #00 screws from the bottom panel of the camera.
Pull off the bottom panel. It may be difficult, but tugging on it shouldn't cause harm to yourself or the device.
Remove the two 4 mm Phillips #00 screws from the inside of the screen hinge.
Remove the black plastic from the back of the screen.
另外一个人完成了本指南。
