跳转到主内容
Sony Handycam FDR-AX33 LCD Screen Replacement
你所需要的
  1. Sony Handycam FDR-AX33 LCD Screen Replacement, Panel: 步骤 1 中的图像 1,2 Sony Handycam FDR-AX33 LCD Screen Replacement, Panel: 步骤 1 中的图像 2,2
    • Remove the battery by pushing the latch towards the body of the camera. Push the battery down and pull it out.
    • Remove the six black 4 mm Phillips #00 screws from the bottom panel of the camera.
    • Pull off the bottom panel. It may be difficult, but tugging on it shouldn't cause harm to yourself or the device.
    • Be sure to un-velcro the handle strap.
  2. Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 2 中的图像 1,3 Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 2 中的图像 2,3 Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Remove the 3 mm Phillips #00 screw from the bottom of the camera.
    • Remove the 4 mm Phillips #00 screw from the right panel.
    • Pull the right panel off. Again, it might be difficult, but pulling hard shouldn't harm you or the camera.
    • You may have to use the opening tool to remove this panel.
  3. Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 3 中的图像 1,2 Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the two 4 mm Phillips #00 screws from the top right corner of the camera.
    • Remove the 4 mm Phillips #00 screw from in front of the flash mount.
  4. Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 4 中的图像 1,2 Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Remove the 3 mm Phillips #00 screw from below the right side of the battery slot.
    • Remove the black 5 mm Phillips #00 screw from the top of the battery slot.
  5. Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 5 中的图像 1,3 Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 5 中的图像 2,3 Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 5 中的图像 3,3
    • Remove the three 4 mm Phillips #00 screws from the left panel underneath the display screen.
    • You’ll need to extend the eyepiece by pulling it out from the body of the camera.
    • Pull the top panel off of the device with the iFixit opening tool.
  6. Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 6 中的图像 1,3 Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 6 中的图像 2,3 Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 6 中的图像 3,3
    • Remove the top and bottom 4 mm Phillips #00 screws from the display screen hinge.
    • Use the iFixit opening tool to remove the screen hinge.
  7. Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 7 中的图像 1,2 Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Remove the 3 mm Phillips #00 screw from between the eyepiece and the panel directly to the right of the battery slot.
    • Angle the eyepiece up to reach the screw with the screwdriver.
    • Take the panel directly to the right of the battery slot off of the camera.
  8. Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 8 中的图像 1,3 Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 8 中的图像 2,3 Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 8 中的图像 3,3
    • Remove the 4 mm Phillips #00 screw above and to the right of the battery slot.
    • Pry the left panel out at an angle by pushing the plastic slat between the battery slot and the eyepiece.
    • Wiggle the left panel and pull it out gently.
    • The left panel can be hard to remove so make sure to apply a good amount of force, but be cautious to not harm yourself or the device.
  9. Sony Handycam FDR-AX33 LCD Screen Replacement, LCD Screen: 步骤 9 中的图像 1,2 Sony Handycam FDR-AX33 LCD Screen Replacement, LCD Screen: 步骤 9 中的图像 2,2
    • Remove the black 3 mm Phillips #00 screw from the middle of the hinge.
    • Remove the two 4 mm Phillips #00 screws from the inside of the screen hinge.
  10. Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 10 中的图像 1,3 Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 10 中的图像 2,3 Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 10 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the back panel of the LCD screen with the black nylon spudger.
    • If the nylon spudger doesn't work, use the metal spudger.
    • The heavy duty spudger can cause serious damage to your device.
    • Remove the hinge cover using the tweezers.
  11. Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 11 中的图像 1,2 Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 11 中的图像 2,2
    • Remove the PCB copper circuits from the blue circuit board by pulling out the flexible plastic connector.
    • The PCB copper circuits are very fragile and break easily, which can irreparably damage your screen.
  12. Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 12 中的图像 1,2 Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 12 中的图像 2,2
    • Remove the two 4 mm Phillips #00 screws from both sides of the connection between the hinge and the screen.
    • These screws are very difficult to reach.
  13. Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 13 中的图像 1,2 Sony Handycam FDR-AX33 LCD Screen Replacement: 步骤 13 中的图像 2,2
    • With the the screen flipped out, pull the screen towards the back of the camera to remove the screen.
    • Don't pull so hard that you risk harming yourself or the device.
结论
3等其他人完成本指南。
Jacob Andreatta
于01/24/19注册
542 声望
创作了3篇指南
团队
Cal Poly, Team S18-G2, White Winter 2019 Cal Poly, Team S18-G2, White Winter 2019 的会员
CPSU-WHITE-W19S18G2
4 名成员
创作了12篇指南
3条评论
I need the PCB behind the LCD. One of the ICs in the top right quadrant was sheared off. any idea other than ebay or pawn shops for salvage electronics?
Thanks in advance!
dominic.j.scavo - 回复
Please can you tell me where to purchase Sony Handycam FDR-AX33 LCD Screen?
mfelizardo@gmail.com
Portugal
Mário Felizardo - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 40
总计 2,461
