跳转到主内容
简介
Can't listen to recording with scratchy or without sound! Follow this speaker replacement guide to once again be able to listen those recordings.
配件
没有特定配件。
  1. Sony Handycam DCR-SR68 Speaker Replacement, Speaker: 步骤 1 中的图像 1,2 Sony Handycam DCR-SR68 Speaker Replacement, Speaker: 步骤 1 中的图像 2,2
    • Remove battery before working on device.
    • Undo hand strap.
    • Get iFixit screwdriver and a JIOS Philips head bit.
  2. Sony Handycam DCR-SR68 Speaker Replacement: 步骤 2 中的图像 1,2 Sony Handycam DCR-SR68 Speaker Replacement: 步骤 2 中的图像 2,2
    • Place device on left side with lens facing right.
    • Using the screwdriver, unscrew the left middle screw.
    • Open the "DC IN" tab.
    • Second screw is revealed.
    • Unscrew this screw.
  3. Sony Handycam DCR-SR68 Speaker Replacement: 步骤 3 中的图像 1,1
    • Turn device onto it's top with the lens facing right.
    • Unscrew the top left and top right screws.
    • Right side casing is now free.
  4. Sony Handycam DCR-SR68 Speaker Replacement: 步骤 4 中的图像 1,2 Sony Handycam DCR-SR68 Speaker Replacement: 步骤 4 中的图像 2,2
    • Remove the right side casing by pulling away.
    • HDD is now revealed.
  5. Sony Handycam DCR-SR68 Speaker Replacement: 步骤 5 中的图像 1,3 Sony Handycam DCR-SR68 Speaker Replacement: 步骤 5 中的图像 2,3 Sony Handycam DCR-SR68 Speaker Replacement: 步骤 5 中的图像 3,3
    • Using your fingers, lift the HDD by it's right end, pivoting on it's left end.
    • HDD ribbon wire is now exposed.
  6. Sony Handycam DCR-SR68 Speaker Replacement: 步骤 6 中的图像 1,2 Sony Handycam DCR-SR68 Speaker Replacement: 步骤 6 中的图像 2,2
    • Using your fingers, pull the ribbon wire out of it's socket.
    • HDD is now free from device.
    • Set HDD aside
  7. Sony Handycam DCR-SR68 Speaker Replacement: 步骤 7 中的图像 1,2 Sony Handycam DCR-SR68 Speaker Replacement: 步骤 7 中的图像 2,2
    • Using your fingers, remove the A/V tab.
  8. Sony Handycam DCR-SR68 Speaker Replacement: 步骤 8 中的图像 1,3 Sony Handycam DCR-SR68 Speaker Replacement: 步骤 8 中的图像 2,3 Sony Handycam DCR-SR68 Speaker Replacement: 步骤 8 中的图像 3,3
    • On the bottom of the device, unscrew the right and middle bottom 3mm Philips screws.
    • Remove panel.
  9. Sony Handycam DCR-SR68 Speaker Replacement: 步骤 9 中的图像 1,2 Sony Handycam DCR-SR68 Speaker Replacement: 步骤 9 中的图像 2,2
    • Using the screwdriver, unscrew the top two black 3mm Philips screws.
    • Lift out the grey tray, being careful when feeding the large ribbon wire though the slot.
  10. Sony Handycam DCR-SR68 Speaker Replacement: 步骤 10 中的图像 1,2 Sony Handycam DCR-SR68 Speaker Replacement: 步骤 10 中的图像 2,2
    • Using the black pointed spudger, carefully pop op the latch on the large ribbon wire's port.
    • Set large ribbon wire aside.
  11. Sony Handycam DCR-SR68 Speaker Replacement: 步骤 11 中的图像 1,3 Sony Handycam DCR-SR68 Speaker Replacement: 步骤 11 中的图像 2,3 Sony Handycam DCR-SR68 Speaker Replacement: 步骤 11 中的图像 3,3
    • Using the blunt tweezers, unplug the red and black wires.
    • Using the blunt tweezers, unplug the small ribbon wire.
  12. Sony Handycam DCR-SR68 Speaker Replacement: 步骤 12 中的图像 1,1
    • Unscrew the top 3 3mm Philips screws from right to left.
  13. Sony Handycam DCR-SR68 Speaker Replacement: 步骤 13 中的图像 1,1
    • On the back of the device, unscrew the top 3mm Philips screw.
  14. Sony Handycam DCR-SR68 Speaker Replacement: 步骤 14 中的图像 1,2 Sony Handycam DCR-SR68 Speaker Replacement: 步骤 14 中的图像 2,2
    • On the left side of the device, unscrew the top 2 3mm Philips screws.
    • The top of the device is now free.
  15. Sony Handycam DCR-SR68 Speaker Replacement: 步骤 15 中的图像 1,2 Sony Handycam DCR-SR68 Speaker Replacement: 步骤 15 中的图像 2,2
    • Remove the top of the device by lifting it upwards.
    • Be careful of the wires becoming snagged on the frame.
  16. Sony Handycam DCR-SR68 Speaker Replacement: 步骤 16 中的图像 1,3 Sony Handycam DCR-SR68 Speaker Replacement: 步骤 16 中的图像 2,3 Sony Handycam DCR-SR68 Speaker Replacement: 步骤 16 中的图像 3,3
    • With the top of the device in hand, remove the 4 visible 3mm Philips screws.
    • Remove the frame by lifting away.
  17. Sony Handycam DCR-SR68 Speaker Replacement: 步骤 17 中的图像 1,2 Sony Handycam DCR-SR68 Speaker Replacement: 步骤 17 中的图像 2,2
    • The speaker is the object on the right with a ribbon wire connecting to it.
    • Remove the broken speaker with your fingers.
    • Replace with new speaker.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 242
