跳转到主内容
Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement
你所需要的
  1. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement, Hard Disk Drive (HDD): 步骤 1 中的图像 1,1
    • Undo Hand Strap
    • Remove battery.
    • Get the iFixit screwdriver and remove the extension.
    • Use a JO Philips head bit.
  2. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 步骤 2 中的图像 1,2 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 步骤 2 中的图像 2,2
    • Place device on left side with lens facing right.
    • Using the screwdriver, unscrew the left middle 3mm Philips screw.
    • Open the "DC IN" tabe. (Second 3mm Philips screw is revealed)
    • Unscrew this screw.
  3. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 步骤 3 中的图像 1,1
    • Turn device over onto it's top with the lens facing right.
    • Unscrew the top left and top right 3mm Philips screws.
    • The right side casing is now free.
  4. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 步骤 4 中的图像 1,2 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 步骤 4 中的图像 2,2
    • Remove the right side casing by pulling up and away.
    • The HDD is now revealed.
  5. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 步骤 5 中的图像 1,3 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 步骤 5 中的图像 2,3 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 步骤 5 中的图像 3,3
    • Using your fingers, lift the HDD from it's right end, pivoting on it's left end.
    • The HDD ribbon wire is now exposed.
  6. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 步骤 6 中的图像 1,2 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 步骤 6 中的图像 2,2
    • Using your fingers, gently pull the ribbon wire out of it's socket.
    • The HDD is now free from the device.
  7. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 步骤 7 中的图像 1,2 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 步骤 7 中的图像 2,2
    • Using your fingers, pull the black rubber bumpers off of the HDD.
    • Set the old HDD aside.
    Hi.
    Easy to replace!
    Where to find a new hdd?
    bernard fradin - 回复
结论
17等其他人完成本指南。
7条评论
Hi. Would you know if the hard drive of the sr67 would work in a sr 68? My sony handycam dcr sr67 Got water damage and I need to download videos. Can't find an old 67. 0nly 68. No one can fix the old one. Thanks renee
Renee - 回复
What does the letter H after hte HDD1818 stands for?
guimoramirez - 回复
My dcr-sr68 hdd not formting please find salution
Naman Jain - 回复
My SONY HANDYCAM DCR - SR68 HDD FORMATING shows Error E:31.00
What does it mean ?
Daanish - 回复
My sony handycam DCR-SR68 HDD not formating plz find
bharat kumar solanki - 回复
Can we use HDD laptop version into this camcorder?
Zinatul Iffah Abdullah - 回复
Where I can purchase hdd
Manoj Kumar Deswal - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 119
总计 9,758
