跳转到主内容
简介
In this guide we well be removing the internal HDD of the DCR-SR68 Handycam and replacing it with a new one. This will involve removing some of the exterior casing to access the HDD.
配件
没有特定配件。
  1. Undo Hand Strap
    • Undo Hand Strap
    • Remove battery.
    • Get the iFixit screwdriver and remove the extension.
    • Use a JO Philips head bit.
  2. Place device on left side with lens facing right. Using the screwdriver, unscrew the  left middle 3mm Philips screw.
    • Place device on left side with lens facing right.
    • Using the screwdriver, unscrew the left middle 3mm Philips screw.
    • Open the "DC IN" tabe. (Second 3mm Philips screw is revealed)
    • Unscrew this screw.
  3. Turn device over onto it's top with the lens facing right.
    • Turn device over onto it's top with the lens facing right.
    • Unscrew the top left and top right 3mm Philips screws.
    • The right side casing is now free.
  4. Remove the right side casing by pulling up and away. The HDD is now revealed.
    • Remove the right side casing by pulling up and away.
    • The HDD is now revealed.
  5. Using your fingers, lift the HDD from it's right end, pivoting on it's left end. The HDD ribbon wire is now exposed. The HDD ribbon wire is now exposed.
    • Using your fingers, lift the HDD from it's right end, pivoting on it's left end.
    • The HDD ribbon wire is now exposed.
  6. Using your fingers, gently pull the ribbon wire out of it's socket. The HDD is now free from the device.
    • Using your fingers, gently pull the ribbon wire out of it's socket.
    • The HDD is now free from the device.
  7. Using your fingers, pull the black rubber bumpers off of the HDD. Set the old HDD aside.
    • Using your fingers, pull the black rubber bumpers off of the HDD.
    • Set the old HDD aside.
结论
9等其他人完成本指南。
Michael Smith
于2016年01月06日注册
197 信誉积分
撰写一个指南
Hi. Would you know if the hard drive of the sr67 would work in a sr 68? My sony handycam dcr sr67 Got water damage and I need to download videos. Can't find an old 67. 0nly 68. No one can fix the old one. Thanks renee
Renee - 回复
What does the letter H after hte HDD1818 stands for?
guimoramirez - 回复
My dcr-sr68 hdd not formting please find salution
Naman Jain - 回复
My SONY HANDYCAM DCR - SR68 HDD FORMATING shows Error E:31.00
What does it mean ?
Daanish - 回复
My sony handycam DCR-SR68 HDD not formating plz find
bharat kumar solanki - 回复
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 17
过去的30天: 99
总计 4,348
