跳转到主内容
修复你的物品
维修的权力
配件 & 工具
配件
没有特定配件。
  1. Wash and dry your hands, then put on a properly grounded anti-static wrist strap, before handling internal electronic components. To ground the wrist strap, attach it to the metal chassis of a plugged-in three prong power supply, of a computer for example.
    • Wash and dry your hands, then put on a properly grounded anti-static wrist strap, before handling internal electronic components. To ground the wrist strap, attach it to the metal chassis of a plugged-in three prong power supply, of a computer for example.
    • Unfasten the hand strap.
    • Remove the battery.
  2. Place device on left side with front lens facing right. Using a JIS size #00 precision Phillips screwdriver, unscrew the left middle 3mm Phillips screw.
    • Place device on left side with front lens facing right.
    • Using a JIS size #00 precision Phillips screwdriver, unscrew the left middle 3mm Phillips screw.
    • Open the "DC IN" plastic tab (Second 3mm Phillips screw is revealed).
    • Unscrew the second 3mm Phillips screw.
  3. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  4. Turn device over onto its top with the front lens facing right.
    • Turn device over onto its top with the front lens facing right.
    • Unscrew the top left and top right 3mm Philips screws.
    • The right side case panel is now unfastened (the case panel facing up in the photo).
  5. Remove the right side case panel by pulling up. The Hard Drive (HDD) is now revealed.
    • Remove the right side case panel by pulling up.
    • The Hard Drive (HDD) is now revealed.
  6. Using your fingers, lift the HDD from its right end, pivoting on its left end. The HDD ribbon wire is now exposed. The HDD ribbon wire is now exposed.
    • Using your fingers, lift the HDD from its right end, pivoting on its left end.
    • The HDD ribbon wire is now exposed.
  7. While securely holding the HDD in your left hand, use the soft pad of your right hand fingers to gently pull the ribbon wire out of its socket, toward your right. The HDD is now free from the device.
    • While securely holding the HDD in your left hand, use the soft pad of your right hand fingers to gently pull the ribbon wire out of its socket, toward your right.
    • The HDD is now free from the device.
    • Replace HDD.
结论
Greg Thorburn
于2016年01月06日注册
263 信誉积分
撰写一个指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 9
总计 375
