跳转到主内容
Sony Handycam DCR-SR42 LCD Screen Replacement
你所需要的
  1. Sony Handycam DCR-SR42 LCD Screen Replacement, Hard Drive: 步骤 1 中的图像 1,2 Sony Handycam DCR-SR42 LCD Screen Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Remove the battery, and use the Phillips #00 precision screwdriver to then remove the three 3mm Phillips #00 screws under the battery.
    • Wait 1 hour after removing the battery before continuing to disassemble the camera.
  2. Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the three 3mm #00 Phillips screws on the bottom of the camera.
  3. Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the three 3mm Phillips #00 screws on the side of the camera.
    • Remove the 4mm Phillips #00 screw under the AV port cover.
  4. Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 4 中的图像 1,2 Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Gently pull the black plastic hard drive cover away from the body of the camera. This will expose the hard drive.
    • Even with all the screws removed, this part will require some force to remove.
  5. Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 5 中的图像 1,2 Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Lift the hard drive out of the camera by grasping the grey rubber mounting brackets and pulling them upwards.
    • The hard drive is attached to the flex cable. Remove the hard drive slowly to prevent the flex cable from being damaged.
  6. Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the rubber mounting brackets by pulling them off the hard drive.
  7. Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Carefully unplug the flex cable from the hard drive.
  8. Sony Handycam DCR-SR42 LCD Screen Replacement, Internal Components: 步骤 8 中的图像 1,2 Sony Handycam DCR-SR42 LCD Screen Replacement, Internal Components: 步骤 8 中的图像 2,2
    • Remove the four 3mm Phillips #00 screws from under the hard drive.
  9. Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 9 中的图像 1,3 Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 9 中的图像 2,3 Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 9 中的图像 3,3
    • Press in on the two tabs as shown and lift the metal plate up and off the camera.
  10. Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 10 中的图像 1,3 Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 10 中的图像 2,3 Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 10 中的图像 3,3
    • Remove the two 4mm Phillips #00 screws from the underside of the camera.
    • Remove the 2 mm Phillips #00 screw from the screen hinge.
  11. Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 11 中的图像 1,3 Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 11 中的图像 2,3 Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 11 中的图像 3,3
    • Use the plastic opening tool to remove the plastic cover from the top of the camera.
    • Remove the two 3mm Phillips #00 screws from underneath the plastic cover.
  12. Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 12 中的图像 1,2 Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 12 中的图像 2,2
    • Remove the second plastic cover from the top of the camera.
    • Remove the 4mm Phillips #00 screw from underneath the cover.
  13. Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 13 中的图像 1,2 Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 13 中的图像 2,2
    • Carefully pry the screen assembly apart from the main body of the camera.
    • Unplug the flex cable from the screen assembly.
  14. Sony Handycam DCR-SR42 LCD Screen Replacement, Flex Cable: 步骤 14 中的图像 1,1
    • Remove the 5 3mm Phillips #00 Screws from the screen assembly.
  15. Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 15 中的图像 1,3 Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 15 中的图像 2,3 Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 15 中的图像 3,3
    • Carefully lift up the sound chip and peel the flex cable off the screen case.
    • Lift off the plastic bracket from the hinge.
  16. Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 16 中的图像 1,2 Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 16 中的图像 2,2
    • Remove the screen from the plastic case by pulling the flex cable and sound chip through the hole in the case.
  17. Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 17 中的图像 1,1
    • Turn the hinge sideways and remove the two 4mm Phillips #00 screws from the side of the screen.
  18. Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 18 中的图像 1,3 Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 18 中的图像 2,3 Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 18 中的图像 3,3
    • Use the plastic opening tool to remove the plastic hinge covers and expose the metal hinge.
    • Unwrap the flex cable from around the hinge.
  19. Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 19 中的图像 1,2 Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 19 中的图像 2,2
    • Use the plastic opening tool to open the screen case.
  20. Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 20 中的图像 1,2 Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 20 中的图像 2,2
    • Unplug the flex cable from the sound chip.
    • Unplug the flex cable from the screen chip.
  21. Sony Handycam DCR-SR42 LCD Screen Replacement, LCD Screen: 步骤 21 中的图像 1,1
    • Unscrew the 2mm Phillips #00 screw from the screen chip.
  22. Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 22 中的图像 1,2 Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 22 中的图像 2,2
    • Remove the LCD screen and chip from the plastic case.
    • Separate the screen from the chip.
  23. Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 23 中的图像 1,2 Sony Handycam DCR-SR42 LCD Screen Replacement: 步骤 23 中的图像 2,2
    • Unplug the screen cable from the screen chip.
结论
6等其他人完成本指南。
Dan Muller
于03/23/15注册
1,020 声望
创作了5篇指南
团队
Baylor, Team 7-13, Williams Spring 2015 Baylor, Team 7-13, Williams Spring 2015 的会员
BU-WILLIAMS-S15S7G13
4 名成员
创作了10篇指南
3条评论
Good narration,but very sofia fixated parts and needs to handle gently and carefully.not an easy
dvsureshkreddy - 回复
What’s a link to a replacement screen?
Rick Astely - 回复
Had a loose hinge on the identical DCR-SR52 (screen was flopping around at the smallest movement), I could not have fixed it without this guide, thanks a lot.
IPaul 6253 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 41
总计 5,532
