跳转到主内容
Sony Handycam DCR-SR 47 LCD Screen Replacement
你所需要的
  1. Sony Handycam DCR-SR 47 LCD Screen Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Remove the battery.
    • Use Philips #000 screwdriver to remove the 3mm screw under the battery
    • *t is recommended that you wait One Hour after removing the battery before disassembling the rest of the camera
  2. Sony Handycam DCR-SR 47 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Using the Phillips #000 screwdriver, remove all 6 of the 3mm screws located on the side of the camera.
    • This step seems unnecessary to initially find the Hard Drive, but will allow access to the attached flex cable
  3. Sony Handycam DCR-SR 47 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Using the Phillips #000 tool, remove the three 3mm screws from under the LCD screen
  4. Sony Handycam DCR-SR 47 LCD Screen Replacement: 步骤 4 中的图像 1,2 Sony Handycam DCR-SR 47 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Using the Phillips #000 screwdriver, remove the one 3mm screw on the back of the camera
    • Pull away the back shell of the camera, exposing the hard drive.
  5. Sony Handycam DCR-SR 47 LCD Screen Replacement: 步骤 5 中的图像 1,3 Sony Handycam DCR-SR 47 LCD Screen Replacement: 步骤 5 中的图像 2,3 Sony Handycam DCR-SR 47 LCD Screen Replacement: 步骤 5 中的图像 3,3
    • Gently pull the flex cable away from the hard drive. It should pop-off with minimal effort.
    • The black guard has been removed in the first picture. The guard does not need to be removed in order to reach hard drive and cable, but it does show the path that the cable takes
    • Once removing the flex cable, remove the plastic guard from the side of the hard drive.
  6. Sony Handycam DCR-SR 47 LCD Screen Replacement, LCD Screen: 步骤 6 中的图像 1,2 Sony Handycam DCR-SR 47 LCD Screen Replacement, LCD Screen: 步骤 6 中的图像 2,2
    • Insert wisdom here.
  7. Sony Handycam DCR-SR 47 LCD Screen Replacement: 步骤 7 中的图像 1,2 Sony Handycam DCR-SR 47 LCD Screen Replacement: 步骤 7 中的图像 2,2
  8. Sony Handycam DCR-SR 47 LCD Screen Replacement: 步骤 8 中的图像 1,2 Sony Handycam DCR-SR 47 LCD Screen Replacement: 步骤 8 中的图像 2,2
    • Using the plastic opening tool, separate the LCD screen from its plastic housing
  9. Sony Handycam DCR-SR 47 LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Using the spudger, or by gently pulling, remove the smaller end of the flex cable from the LCD Screen
  10. Sony Handycam DCR-SR 47 LCD Screen Replacement: 步骤 10 中的图像 1,2 Sony Handycam DCR-SR 47 LCD Screen Replacement: 步骤 10 中的图像 2,2
    • Using the Phillips #000 Screwdriver, remove the one 3mm screw from the LCD Scren
    • The LCD screen may now be removed from the camera completely.
  11. Sony Handycam DCR-SR 47 LCD Screen Replacement: 步骤 11 中的图像 1,2 Sony Handycam DCR-SR 47 LCD Screen Replacement: 步骤 11 中的图像 2,2
    • Take the LCD screen away from the housing and replace with new screen
结论
2等其他人完成本指南。
一条评论
where can i buy a screen for this camera?
Triforce Studios - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 1,145
