跳转到主内容
Sony Handycam DCR-DVD103 Lens Replacement
你所需要的
  1. Sony Handycam DCR-DVD103 Lens Replacement, Battery: 步骤 1 中的图像 1,1
    • Images do not show the camera's battery.
    • On the back of the camera beneath the viewfinder, locate the battery pack.
    • Press the small button.
    • Slide the switch forward.
  2. Sony Handycam DCR-DVD103 Lens Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from the camera.
    • To reinsert the battery, slide the battery into the camera.
  3. Sony Handycam DCR-DVD103 Lens Replacement, Outer Cover: 步骤 3 中的图像 1,1
    • Using a #00 Phillips screwdriver, remove the six 4.5 mm screws from the camera's bottom.
  4. Sony Handycam DCR-DVD103 Lens Replacement: 步骤 4 中的图像 1,2 Sony Handycam DCR-DVD103 Lens Replacement: 步骤 4 中的图像 2,2
    • Remove the three 4.5 mm screws beneath the battery.
    • Remove the 2.9 mm screw from the right corner.
    • Remove the two 4.5 mm screws from the battery's right wall.
    • Images do not show the battery.
  5. Sony Handycam DCR-DVD103 Lens Replacement: 步骤 5 中的图像 1,1
    • Remove the 4.5 mm screw under the output flap on the front of the camera below the lens.
  6. Sony Handycam DCR-DVD103 Lens Replacement: 步骤 6 中的图像 1,2 Sony Handycam DCR-DVD103 Lens Replacement: 步骤 6 中的图像 2,2
    • Remove the two 4.5 mm screws at the top of the camera.
    • Remove the 4.5 mm screw from the disk side of the camera (next to the lens).
  7. Sony Handycam DCR-DVD103 Lens Replacement: 步骤 7 中的图像 1,2 Sony Handycam DCR-DVD103 Lens Replacement: 步骤 7 中的图像 2,2
    • Extend the gray viewfinder, then gently remove the black plastic casing.
    • Caution: Plastic pieces are fragile.
  8. Sony Handycam DCR-DVD103 Lens Replacement: 步骤 8 中的图像 1,1
    • Remove the two 2.9 mm screws under the black plastic casing.
  9. Sony Handycam DCR-DVD103 Lens Replacement: 步骤 9 中的图像 1,1
    • Gently pull apart the outer silver case and screen.
    • Remove the copper wire strip to detach the case from the camera.
  10. Sony Handycam DCR-DVD103 Lens Replacement, Lens: 步骤 10 中的图像 1,1
    • Remove the 4.5 mm thread that connects the lens to the camera body.
  11. Sony Handycam DCR-DVD103 Lens Replacement: 步骤 11 中的图像 1,2 Sony Handycam DCR-DVD103 Lens Replacement: 步骤 11 中的图像 2,2
    • Remove the two 4.5 mm screws from the bottom left and top left of the lens casing.
    • Remove the two 2.9 mm screws from the top right and bottom right of the lens casing.
  12. Sony Handycam DCR-DVD103 Lens Replacement: 步骤 12 中的图像 1,1
    • Gently slide the ribbon cables away from their connections on the motherboard.
    • Caution: Too much force will tear the cables.
  13. Sony Handycam DCR-DVD103 Lens Replacement: 步骤 13 中的图像 1,1
    • Remove the 4.5 mm screw that connects the camera body to the lens on the DVD side of the camera.
  14. Sony Handycam DCR-DVD103 Lens Replacement: 步骤 14 中的图像 1,3 Sony Handycam DCR-DVD103 Lens Replacement: 步骤 14 中的图像 2,3 Sony Handycam DCR-DVD103 Lens Replacement: 步骤 14 中的图像 3,3
    • Remove the five 2.9 mm screws connected to the circuit board.
    • Remove the circuit board from the camera.
    • Remove the five copper wires attached to the circuit board.
  15. Sony Handycam DCR-DVD103 Lens Replacement: 步骤 15 中的图像 1,2 Sony Handycam DCR-DVD103 Lens Replacement: 步骤 15 中的图像 2,2
    • Unscrew the three 2.9 mm black screws to remove the metal bracket from the lens.
  16. Sony Handycam DCR-DVD103 Lens Replacement: 步骤 16 中的图像 1,2 Sony Handycam DCR-DVD103 Lens Replacement: 步骤 16 中的图像 2,2
    • Remove the two silver 4.5 mm screws from the bottom of the lens.
    • Caution: Be careful with the lens once the screws are removed. The lens contains a small piece of glass that can fall out.
结论
2等其他人完成本指南。
kaitlin
于01/11/11注册
342 声望
创作了3篇指南
团队
Cal Poly, Team 7-44, Regan Winter 2011 Cal Poly, Team 7-44, Regan Winter 2011 的会员
CPSU-REGAN-W11S7G44
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 4,632
