跳转到主内容
Sony Handycam DCR-DVD103 Laser Disc Replacement
你所需要的
  1. Sony Handycam DCR-DVD103 Laser Disc Replacement, Battery: 步骤 1 中的图像 1,1
    • Images do not show the camera's battery.
    • On the back of the camera beneath the viewfinder, locate the battery pack.
    • Press the small button.
    • Slide the switch forward.
  2. Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from the camera.
    • To reinsert the battery, slide the battery into the camera.
  3. Sony Handycam DCR-DVD103 Laser Disc Replacement, Outer Cover: 步骤 3 中的图像 1,1
    • Using a #00 Phillips screwdriver, remove the six 4.5 mm screws from the camera's bottom.
  4. Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 4 中的图像 1,2 Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 4 中的图像 2,2
    • Remove the three 4.5 mm screws beneath the battery.
    • Remove the 2.9 mm screw from the right corner.
    • Remove the two 4.5 mm screws from the battery's right wall.
    • Images do not show the battery.
  5. Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 5 中的图像 1,1
    • Remove the 4.5 mm screw under the output flap on the front of the camera below the lens.
  6. Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 6 中的图像 1,2 Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 6 中的图像 2,2
    • Remove the two 4.5 mm screws at the top of the camera.
    • Remove the 4.5 mm screw from the disk side of the camera (next to the lens).
  7. Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 7 中的图像 1,2 Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 7 中的图像 2,2
    • Extend the gray viewfinder, then gently remove the black plastic casing.
    • Caution: Plastic pieces are fragile.
  8. Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 8 中的图像 1,1
    • Remove the two 2.9 mm screws under the black plastic casing.
  9. Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 9 中的图像 1,1
    • Gently pull apart the outer silver case and screen.
    • Remove the copper wire strip to detach the case from the camera.
  10. Sony Handycam DCR-DVD103 Laser Disc Replacement, Laser Disc: 步骤 10 中的图像 1,3 Sony Handycam DCR-DVD103 Laser Disc Replacement, Laser Disc: 步骤 10 中的图像 2,3 Sony Handycam DCR-DVD103 Laser Disc Replacement, Laser Disc: 步骤 10 中的图像 3,3
    • Remove (1) 2.9mm screw from under the eye piece.
    • Remove (1) 2.9mm screw from above the eye piece.
    • Remove (4) copper strips from bellow the eye piece.
    • Pull off the eye piece assembly.
  11. Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 11 中的图像 1,1
    • Pull off back cover. Caution: Be careful not to tear any copper strips in the process.
    • Remove (4) copper strips in order to pull off eye piece.
  12. Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 12 中的图像 1,1
    • Remove (4) 3.6mm wide head screws on the laser reader.
    • Note: There are rubber rings around screws that easily fall off.
  13. Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 13 中的图像 1,3 Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 13 中的图像 2,3 Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 13 中的图像 3,3
    • Unplug copper strip and lift up.
    • Pull off tape over 2.3mm screw.
    • Remove (1) 2.3mm screw from under the tape.
  14. Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 14 中的图像 1,2 Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 14 中的图像 2,2
    • Pull the copper strip, marked by the red rectangle, through the hole behind it, marked with the yellow rectangle.
  15. Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 15 中的图像 1,3 Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 15 中的图像 2,3 Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 15 中的图像 3,3
    • Remove (3) 2.9mm screws from top circuit board.
    • Note: Circuit board will resist trying to be pulled off so pull it off with care but still firmly.
    • Lift up circuit board and remove (1) 2.9mm screw underneath.
    • Pull out copper plate with rubber insulator on it.
  16. Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 16 中的图像 1,3 Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 16 中的图像 2,3 Sony Handycam DCR-DVD103 Laser Disc Replacement: 步骤 16 中的图像 3,3
    • Remove tape over copper strip in the bottom left corner and pull out copper strip.
    • Remove laser reader assembly.
结论
另外一个人完成了本指南。
Lauren
于01/05/11注册
253 声望
创作了2篇指南
团队
Cal Poly, Team 7-44, Regan Winter 2011 Cal Poly, Team 7-44, Regan Winter 2011 的会员
CPSU-REGAN-W11S7G44
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 23
总计 3,486
