跳转到主内容
Sony HDR-AS30V LCD Screen Replacement
你所需要的
  1. Sony HDR-AS30V LCD Screen Replacement, Outer Casing: 步骤 1 中的图像 1,1
    • Power off the device. Remove the component jack cover.
    • Open component door.
    • Using the Phillips 00 screwdriver, remove the two screws holding the jack cover in place.
  2. Sony HDR-AS30V LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Open the battery door.
    • Slide the battery cap along the length of the camera, then flip the cap outward. Use caution; there may be internal damage affecting the functionality of the sliding mechanism.
  3. Sony HDR-AS30V LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Prepare to remove outer casing.
    • Using the 2.5 mm precision slotted screwdriver, insert the tip of the screwdriver under the holder to wedge. Use caution when preparing to wedge apart fragile components.
  4. Sony HDR-AS30V LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Separate Casing from Device.
    • With the screwdriver wedged, apply slight force while pulling the casing away from the device. Use caution to avoid causing damage to fragile parts.
  5. Sony HDR-AS30V LCD Screen Replacement: 步骤 5 中的图像 1,1
    • With the outer casing pulled away from the device, take note of the orientation of the inner component to avoid an electrical short.
    • Once the orientation of the inner component is noted, slide the inner component out of the casing. You may now replace the broken casing with a new one.
  6. Sony HDR-AS30V LCD Screen Replacement, LCD Screen: 步骤 6 中的图像 1,1
    • Remove two screws with the PH000 screwdriver.
    • Pop off plastic holder.
  7. Sony HDR-AS30V LCD Screen Replacement: 步骤 7 中的图像 1,1
    • With the flathead screwdriver, wedge under area shown and pop upwards.
    • Be sure to move the flex cable out of the way while flipping the plastic inner casing upward.
  8. Sony HDR-AS30V LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Gently push speaker out of slot
  9. Sony HDR-AS30V LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Flip open screen and make sure no cables are in the way.
  10. Sony HDR-AS30V LCD Screen Replacement: 步骤 10 中的图像 1,1
    • With the flathead, lift up cable lock and pull the film out from underneath the lock.
  11. Sony HDR-AS30V LCD Screen Replacement: 步骤 11 中的图像 1,1
    • Gently pull out screen.
结论
另外一个人完成了本指南。
Dylan Keiter
于01/28/15注册
119 声望
撰写一个指南
团队
Penn State, Team 2-12, Kaschak Winter 2015 Penn State, Team 2-12, Kaschak Winter 2015 的会员
PSU-KASCHAK-W15S2G12
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 624
