跳转到主内容
Sony H.ear On 2 Ear Cup Replacement
你所需要的
  1. Sony H.ear On 2 Ear Cup Replacement, Ear Cup: 步骤 1 中的图像 1,2 Sony H.ear On 2 Ear Cup Replacement, Ear Cup: 步骤 1 中的图像 2,2
    • Start by inserting the iFixit plastic opening tool in the crease between the hard plastic and the ear cup, and then gently apply pressure until it separates. You may need to repeat the process on back until it is completely separate.
    • This may take a considerable amount of pressure, but do not force it.
  2. Sony H.ear On 2 Ear Cup Replacement: 步骤 2 中的图像 1,2 Sony H.ear On 2 Ear Cup Replacement: 步骤 2 中的图像 2,2
    • Use the JIS #00 Screwdriver to remove the five 6.4 mm screws holding the back plastic cover in place.
    • Then, turn the ear cup over and carefully lift the plastic cap off to reveal the internal components of the left ear cup.
    • This same process can be repeated on the right ear cup as well. Be aware the right cup is connected to the rest of the headphones via ribbon cable.
结论
另外一个人完成了本指南。
Alec Saffer
于04/15/19注册
522 声望
创作了2篇指南
团队
Cal Poly, Team S9-G11, Maness Spring 2019 Cal Poly, Team S9-G11, Maness Spring 2019 的会员
CPSU-MANESS-S19S9G11
5 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 36
总计 3,417
