跳转到主内容
Sony FDL-220R Watchman Button Replacement
你所需要的
  1. Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: 步骤 1 中的图像 1,2 Sony FDL-220R Watchman Button Replacement, Remove battery cover and batteries: 步骤 1 中的图像 2,2
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Button Replacement, Remove screws: 步骤 2 中的图像 1,2 Sony FDL-220R Watchman Button Replacement, Remove screws: 步骤 2 中的图像 2,2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Philips #00 screwdriver.
  3. Sony FDL-220R Watchman Button Replacement, Remove back casing: 步骤 3 中的图像 1,2 Sony FDL-220R Watchman Button Replacement, Remove back casing: 步骤 3 中的图像 2,2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
  4. Sony FDL-220R Watchman Button Replacement, Remove circuit board: 步骤 4 中的图像 1,3 Sony FDL-220R Watchman Button Replacement, Remove circuit board: 步骤 4 中的图像 2,3 Sony FDL-220R Watchman Button Replacement, Remove circuit board: 步骤 4 中的图像 3,3
    • Carefully grasp the entire circuit board.
    • Pull the circuit board off of the device's plastic casing.
  5. Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: 步骤 5 中的图像 1,2 Sony FDL-220R Watchman Button Replacement, Remove/Replace Buttons: 步骤 5 中的图像 2,2
    • Locate the thee plastic buttons/switches on the sides of the plastic grey casing.
    • Buttons/switches should be simply resting in their slots on the device.
    • Remove all three buttons/switches.
    • If the buttons/switches are dirty, clean them in warm water and dry thoroughly.
    • If one of the buttons/switches is broken, simply replace it with a new one.
    • When replacing, make sure that the slot on the switches faces up.
结论
Sam Putnam
于10/22/14注册
484 声望
创作了4篇指南
团队
Baylor, Team 4-5, Williams Fall 2014 Baylor, Team 4-5, Williams Fall 2014 的会员
BU-WILLIAMS-F14S4G5
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 267
