跳转到主内容
Sony Ericsson z300 Vibrator Replacement
你所需要的
  1. Sony Ericsson z300 Vibrator Replacement, Back Phone Cover: 步骤 1 中的图像 1,1
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Sony Ericsson z300 Vibrator Replacement, Battery: 步骤 2 中的图像 1,1
    • Using a fingernail lift the battery out of the phone.
  3. Sony Ericsson z300 Vibrator Replacement, Front Phone Cover: 步骤 3 中的图像 1,1
    • To remove the front cover, lift up the case with a fingernail in the small slot as shown.
  4. Sony Ericsson z300 Vibrator Replacement, Front Dark Grey Case: 步骤 4 中的图像 1,1
    • To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
  5. Sony Ericsson z300 Vibrator Replacement: 步骤 5 中的图像 1,1
    • Pry up the dark grey case with your fingernail until all four snaps around the top are loose.
  6. Sony Ericsson z300 Vibrator Replacement: 步骤 6 中的图像 1,1
    • Lift up towards the bottom and slide the case off.
  7. Sony Ericsson z300 Vibrator Replacement, Screens: 步骤 7 中的图像 1,1
    • Use a plastic opening tool to lift the black tape off of the ribbon cable connector.
  8. Sony Ericsson z300 Vibrator Replacement: 步骤 8 中的图像 1,1
    • Lift the ribbon cable connector lock using a plastic opening tool.
  9. Sony Ericsson z300 Vibrator Replacement: 步骤 9 中的图像 1,2 Sony Ericsson z300 Vibrator Replacement: 步骤 9 中的图像 2,2
    • Slide the black ribbon cable tray out with a plastic opening tool.
    • Shown in the second picture is the try already slid out.
  10. Sony Ericsson z300 Vibrator Replacement: 步骤 10 中的图像 1,2 Sony Ericsson z300 Vibrator Replacement: 步骤 10 中的图像 2,2
    • Slide the ribbon cable out of the connector.
    • Shown in the second picture is the cable already out.
  11. Sony Ericsson z300 Vibrator Replacement: 步骤 11 中的图像 1,1
    • Use a plastic opening tool to lift up on the screen board and release the clips holding it in place.
    • Lift the entire board out of the phone to remove both screens.
  12. Sony Ericsson z300 Vibrator Replacement, Vibrator: 步骤 12 中的图像 1,1
    • Use a plastic opening tool to lift the vibrator out of its slot.
结论
Alex Serventi
于10/07/10注册
65 声望
创作了13篇指南
团队
Cal Poly, Team 5-15, Maness Fall 2010 Cal Poly, Team 5-15, Maness Fall 2010 的会员
CPSU-MANESS-F10S5G15
4 名成员
创作了26篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 2,147
